Rockford Fosgate T2500-1bdcp
Old 10th February 2018, 04:52 PM   #1
seankane is offline seankane  United States
seankane's Avatar
Default Rockford Fosgate T2500-1bdcp
I have repaired power supply and output stage. The amp powers up and produces clean audio. The amp is drawing about 8-10 amps at idle. This is too much compared to my other ones. Any ideas what could cause the excess current draw?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 10th February 2018, 04:59 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Quiescent current too high, if class D then the dead time setting is too small. Power supply tuning issues etc etc etc.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 10th February 2018, 06:21 PM   #3
seankane's Avatar
The amp originally had some of the outputs fail due to one of the insulators between the FET's and the heat sink become conductive and short to the heat sink. There were a few SMD transistors failed as well. Someone had also changed only one power supply FET. I changed them all as to have matching date codes. I replaced all the outputs as well. Nothing seems to be getting hot just can't pin point the current draw.
It does produce clean audio.
Old 10th February 2018, 06:51 PM   #4
seankane's Avatar
I have 5.60vdc on all power supply gate legs, half the power supply has a nice square wave on the gate leg. The other half is a square wave as well but it looks different. The wave is much further above and below the reference line and a lot closer together.
Old 17th February 2018, 03:00 AM   #5
Perry Babin is offline Perry Babin  United States
Photo?
Old 18th February 2018, 07:05 PM   #6
seankane's Avatar
I apologize for the pic quality. My big scope is down had to use the hand held.
It looks like one supply is idle and the other is at higher duty cycle?
The scope is in auto range not sure why one reading was in "ms" and the other "us".
Old 18th February 2018, 11:16 PM   #7
Aren't they the same with a different scope timebase setting?
Old 19th February 2018, 03:58 AM   #8
seankane's Avatar
Why wouldn't the scope read them the same in auto range? Why would one be in ms and the other in us?
Old 20th February 2018, 01:23 AM   #9
The scope probably tries to decide which will give the best view of the signal. Maybe one of the things it used to make the choice was on the border and it chose differently.
Old 20th February 2018, 01:54 AM   #10
seankane's Avatar
Just not sure where to begin hunting this current draw. I guess I'll keep digging.
If those signals look fine to you, then I will move on somewhere different.
Rockford Fosgate T2500-1bdcpHide this!Advertise here!
T1500-1bdcp Rockford fosgate DREW028 Car Audio 17 14th March 2019 05:57 PM
Rockford T2500-1bdCP Schematic / Service manual? Troy Dionne Car Audio 10 10th February 2019 02:04 AM
Rockford Fosgate T2500-1BDCP PaleFaceRider202 Car Audio 4 5th February 2018 11:34 PM
Rockford Fosgate T-2500-1BDCP josesony68 Car Audio 15 6th November 2016 08:04 AM
Rockford Fosgate T2500-1bdcp Parts rizzo30 Parts 2 4th January 2012 12:41 AM
Copyright ©1999-2019 diyAudio
