Using ported speakers in open baffle set up. Home speakers in car
Thread Tools
Old 3rd February 2018, 03:12 AM   #1
Richard_James is offline Richard_James
Default Using ported speakers in open baffle set up. Home speakers in car
Hi I have Cambridge audio m60 speakers that sound amazing ly good. These are ported speakers.
What if I use them in my car. There is a minimal space to build boxes. Currently they are in about 1 cubic feet boxes ..ported boxes.
They will be used with old Alpine amp that delivers true 50 watts per channel.
I've heard since drivers don't have dumping property of the box they can get damaged.
I am just thinking that since the drivers are already in ported boxes.. they are sort of designed for minimal damping. Can I just slap them into the doors and not build boxes for them. It's a bit of a hustle to build and fix boxes into the doors
Old 3rd February 2018, 09:21 AM   #2
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
The main problem with using non car speakers in cars particularly the doors is that they are not designed for the hostile environment and will probably rot and warp in time
Old 4th February 2018, 09:40 PM   #3
phase is offline phase  United States
Typically so, with a paper cone, but these have a poly driver of some sort.
I would do what you are thinking, and provided you take care with your installation, it should sound nice. Keep in mind that they are 8 ohm, and you will need a larger amp to run them.
I did a similar install starting with a set of JBL Ti tweeters, and just recreated the 4406 into my doors, keeping the crossovers in the kick panels forward of the doors. The factory speakers had a shroud over the upper portion to keep water from dripping on them, and I kept those. I use an older Nakamichi PA300 amp that is rated at 70wpc, and it sounds fine.
Old 5th February 2018, 12:32 AM   #4
Yes these are pretty weather proof. Rubber material and some plastic material cones.. my only worry is open baffle situation. There is no box to help woofers. No air suspension. But the speakers came in ported boxes. I play music loud sometimes. Will I have an issue like woofer bottoms out quickly, or just tears out. I doubt it's an issue. I might build sealed boxes about one third of original volume. U think boxes will help with better bass response? Normally subwoofer manufacturers suggest sealed box to be half the size of ported box. So if u decide to use the sub in ported box it needs to be twice the size of the sealed box if u were to use the same sub in sealed set up
Old 5th February 2018, 12:35 AM   #5
I think I have plenty of power. For a pair or 8ohm speakers. These are very efficient. And 8 ohm in theory should help the amp to run cooler. This one does get hot. In summer if on a long drive with bass heavy music it can shut down. I also have a 12" oionerr subwoofer powered by same amp. Shallow mount pioneer 1500w max. It's getting around 150w though
  Reply to this post
Using ported speakers in open baffle set up. Home speakers in carHide this!Advertise here!
Thread Tools
FS: Open baffle speakers Milkduds Swap Meet 2 28th January 2018 07:44 PM
Open Baffle Speakers nzlowie Multi-Way 33 13th December 2016 03:53 PM
Open Baffle - 3 way speakers lluiz Multi-Way 4 7th June 2014 08:33 AM
My old open baffle speakers, UK-only SimontY Swap Meet 10 19th September 2010 12:40 PM
DRC, with open baffle speakers otto88 Multi-Way 23 22nd May 2010 05:04 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
