2008 Kicker zx2500 help
Old 31st January 2018, 07:26 AM   #1
Krazyiiz is offline Krazyiiz
Default 2008 Kicker zx2500 help
Iím new to this
Iíve read all the threads on the zx2500
Having trouble finding the part # for D702 and D703
They are the large diodes located by the B+ and Ground terminals
The insulation is missing on mine, and the pics of the zx2500 Iíve seen on these threads show a partial part # ďA 6Ē
As seen in the pic I borrowed
Also, looking for part # for the resistors on the output section labeled R316 and R310, between the mosfets labeled Q314 and Q313
It looks like there have been some previous ďrepairsĒ done behind the mosfets on the circuit board itself with a piece of wire
Maybe thatís causing the continuity Iím seeing between all the resistors and fets in that bank
The rest of the board seems fine
I hope Iím using the right terminology and that this is making sense to someone 😂
File Type: jpeg 2669254A-EC78-4832-9449-2A368CB9EAD6.jpeg (230.1 KB, 30 views)
File Type: jpg 75F27C5E-1E3B-4BBA-A02E-BB57D798EDCB.jpg (154.2 KB, 28 views)
Old 31st January 2018, 09:57 AM   #2
MarioRestucci is offline MarioRestucci  Italy
MarioRestucci's Avatar
They are "INVERTED POLARITY" protection diodes.
If you accidentally invert the power cables, this diode blow your amp fuse to self-protect.
You can replace it with this https://www.tme.eu/it/Document/be2d9.../10a05_ser.pdf
Old 31st January 2018, 01:22 PM   #3
Thanks for the quick reply!
So I’m assuming it’s a 10A6 then?
Or can I replace it with anyone of these rectifier diodes on this data sheet?
Old 31st January 2018, 01:40 PM   #4
You can use diodes that have huge amperage and right voltage capability, so the diodes that i've posted are ok!
p.s. R316 = 100Kohm - R310 = 10ohm
Old 31st January 2018, 01:52 PM   #5
Thank you very much
I’ll post how things turn out when the new parts come in
Gonna replace all the 3205’s, 9640’s and 640’s mosfets
Along with any 100kohm and 10ohm resistors showing continuity
And those two rectifier diodes by the power supply
Old 31st January 2018, 02:07 PM   #6
Those are 1/4w resistors right ����*♂️?
Old 31st January 2018, 02:45 PM   #7
yes
2008 Kicker zx2500 helpHide this!Advertise here!
Kicker ZX2500.1 Jason Smith 616 Car Audio 5 18th January 2018 07:16 AM
Kicker ZX2500.1 Jason Smith 616 Car Audio 24 22nd May 2017 01:30 AM
Kicker ZX2500 No output Deadly Sones Car Audio 14 27th April 2017 02:28 AM
Kicker ZX2500.1 RJohns777 Car Audio 13 27th July 2014 02:52 AM
Kicker ZX2500.1 Dr Zeus Car Audio 19 27th January 2011 09:41 PM
