Gain control on gen 1 Orion amplifiers
Old 7th December 2018, 06:36 PM   #71
GEM 592 is offline GEM 592  United States
Originally Posted by Gioba View Post
Hi, have you replaced the caps 470 uF after the leveling capacity (the four axial caps)?
For Orion moon & stars is the first thing to fix, maybe it's the cause.
Those are 3300uF 25V on these amps, but no I haven't. Thanks.
Old 8th December 2018, 04:44 AM   #72
I have had this amp hooked up and used constantly for a few days now, just as I left it before, and the problem hasn't reappeared yet. When it does, and it will, I will check if either muting transistor has come on by measuring gate voltages, and update.
On the other amp, I replaced the two power supply 3300uF 16V caps and the problem persists. When powered up, without any signal input, it puts out steady high-pitched noise. When I connect signals, both channels play but are very noisy. There are no obvious signs of damage, the gain pot has been cleaned, I'm not sure how to proceed. Perhaps I will start by making a new thread about it.
Old 8th December 2018, 06:43 AM   #73
Perry Babin is offline Perry Babin  United States
Please don't mix repairs in a thread.
Old 8th December 2018, 12:54 PM   #74
Gioba is offline Gioba  Italy
Gioba's Avatar
Sorry, maybe i don't write exactly.
I say the two caps 16v/470 uF downstream the leveling caps (those axials).
These ever are the first fixing in my Orion moon & stars, and cause the problems you tell.
Old 8th December 2018, 02:15 PM   #75
Ah yes I thought you might have meant those.
You are right, in the second amp that has noise now those have not been replaced, thank you very much for the tip. Probably should just replace them.
DMM, good power supply, soldering iron, soldering skills.
Old 8th December 2018, 11:41 PM   #76
Gioba's Avatar
Yes, is the same thing of 250 amp, these two caps to fix as soon.
And cleaning good, cap's acid can cause damages to PCB and components.
And hope you resolve the problem, but if it isn't that, those two dangerous caps must to be replaced anyway.
Gain control on gen 1 Orion amplifiersHide this!Advertise here!
Orion amp bypass for the ESP board gain Perry Babin Car Audio 4 17th May 2017 10:29 AM
Just a simple current gain stage with bias control to club with high gain valve pre rhythmsandy Solid State 4 5th May 2017 10:15 AM
Gain control - using integrated amp for adjusting gain? Audiodidakt Multi-Way 4 18th May 2016 02:49 PM
Power Amplifiers & Gain Kaidanovsky Tubes / Valves 3 8th November 2011 12:11 AM
Orion 2150gx gain control problem CBR Car Audio 1 11th March 2010 10:15 PM
