SMPS pictures
Hello Dears
This is a Rod Elliott SMPS that I build.
http://i129.photobucket.com/albums/...rjuris/SMPS.jpg
http://i129.photobucket.com/albums/...juris/SMPS2.jpg
http://i129.photobucket.com/albums/...erjuris/PWM.jpg
http://i129.photobucket.com/albums/...s/powers009.jpg
Good SMPS, no "humms", no "bzzzz".
Hello Dears
weird noise from transformer
Hi!
I'm making a battery powered powersupply, wich makes 2x50V, at about 6-700W. For testing, I'm loading the power supply with 2 amplifiers, and drive them with music.
When I turn the volume to higher levels, then strange sounds are coming from the transformer (ETD44). I recorded the sound with a webcam's microphone:
http://sziget.mine.nu/~danko/aramkor/trafo_1.mp3
http://sziget.mine.nu/~danko/aramkor/trafo_2.mp3
Unfortunatelly the computer picks up a lot of noise, even when the 12V powered supply is turned off. So please ignore that noise, which is on the records...
I don't think, that the feedback is oscillating, becouse that rasping voice is not a "discrete" frequenzy. I have looked on the powersupply's output with my scope, I haven't seen any signs of oscillation.
After that, I thought, maybe the "E" cores aren't clamped perfectly. So I changed the "clamping" to a harder one, but that weird noise was the same...
Maybe, the core is saturating? I dont think... Becouse then my mosfets would blow up There is a current limit in this SMPS, but that's only an "overload limit", not a cycle-by-cycle type current limit.
Have anyone experienced like this?
P.S.: I can post pictures of the board, and schematic, if it's needed
Hi!
Here's the power-section, and a picture of the panel.
http://sziget.mine.nu/~danko/aramkor/car-smps/dscn0431.jpg
On the left side, there are the mosfet driver ICs.
On the right side there's a 8pin IC socket. That WAS the controlling part some time ago. That's not used, I use instead of that the TL494, on a small board.
Hi! There are "solderable" wires, wich means, that you can remove the lacquer by heating the wire with your soldering iron. Unfortunatelly my wire isn't this type. I have to use a hungarian conservating stuff. Transating that material to english, it's called "salycic". I hope you know what i'm talking about
I pour some salycic on the table, put inside it the wire, and I heat them with my soldering iron. The salycic melts, and it gets off the lacquer from the copper. It is VERY smelly! When I soldered those wires I put about 20 wires into the salycic simultaneusly.
what do you think about this?
http://sound.westhost.com/project09.htm
are there any better choice instead of x-over?
transformer Kit
Yes I would be interested in one kit like that ;D
zagisrule! said:Glad to hear it 2pist
I was thinking today about offering a kit including all parts (PCB, MOSFET's, transformer, IC, misc components) for a SMPS. It would be easier for many here to make their GC car amps when all they have to do is assemble a kit and be guranteed a working design.
Would anyone be interested in something like that?
-Matt
Re: Commentable Thoughts
Thanks ;D
do you have pcb also?
Workhorse said:
ThanX for ur interest
here is schematics
Thanks ;D
tico70 said:himanshuraval,
Just a question, are you using a heatsink for the mosfets?
I am using the following circuit and it work perfectly. I am still working with two types of cores (toroid and ETD39)...for now the toroid is performing better and much easier to wind..
Do you have pcb for this?
- General Interest
- Car Audio
- Making car amplifier SMPS with tl494 + DC Protection
