when checking op amp parts in car amps
should i all ways start with the one closest to the rca jacks?
do they seem to good bad first?
Can you post the schematic first?
Look at the schematic and find the op-amp that is first in the input chain and test them on down the line to see where the problem is. Depending on the op-amp but most are Vcc +/- on pins 4 and 8 and output pins are 1 and 7. If you have dc on the output pins of one or more op-amps you need to find the one that is leaky.
If you de-solder pins 4 and or 8 it will disable it.
