Did you check the driver transistors for shorts and open junctions?
Do you have a scope?
I checked R265,R266,R267,R250,R279
R274,R275,R268,R252,R280
Is there something i missed?
No I do not have a scope yet.
You have to check all parts in the red rectangles (and maybe others).
For Q220,Q221,Q222,Q223 do I test for voltage passing through? or iam I checking for the one leg of the diode?
You test to make sure that there are no shorted junctions and no open junctions just like any other BJT transistor.
I belive that Q222, and Q223 are bad. They are open both ways on both legs.
Would these be good replacements?
MMBT 3906 LT1 Infineon Technologies | Mouser
SMMBT3904LT1G ON Semiconductor | Mouser
You will connect the resistors in parallel to each other then the group in series with the B+ wire going to the amp. You will then connect your voltmeter (set to DC volts) across the resistor.
The voltage across the resistor will give you an indication of the current through the resistors.
What is the DC voltage across the resistors at idle?
- General Interest
- Car Audio
- Rockford 500a2
