I recently (today) installed two new 4" subs in my car. I have them hooked to a 200 watt 2 channel boss amp on 16 gauge wire. The wire from the amp to the battery is 10 gauge. I dont have any engine noise from my 12" sub or my factory speakers. What gives? Thanks in advance!
Make sure that none of the speaker wires or the RCAs are shorted to ground. You'll need to disconnect the RCAs at both ends to check them. Remove the speaker wires from the speaker terminals on the amp before checking them.
Is the signal source for the new speakers feeding any other amp?
