JLHD 750Watts - high rail voltage
Old 2nd October 2015, 07:11 AM   #1
nonprof is offline nonprof
Default JLHD 750Watts - high rail voltage
Hello!
I want to restore this amp after a couple of years stuck. But I think my limitation had reached on this amp, the rail voltages is too high, it produces high AC voltage up to 110V. Putting back the rectifier diode the DC voltage reached up to 120VDC and this diode gets too hot...
I measured the PS switching freq around 49Khz. I have a perfect gate square wave into IRF3205s mosfets.
Please help...
Old 2nd October 2015, 09:35 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
If too high I expect the regulation has failed. The PSU will be either pulse width modulation or frequency regulated. In the latter, the frequency rises and the transformer gets less efficient so the voltage produced gets less.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 2nd October 2015, 09:53 AM   #3
So do you mean I should get higher frequency to make the voltage lower? This amp is PWM or a frequency modulated? I've seen the McIntosh amp, it is PWM regulation.
I have schematic of this amp, could somebody tell me which part of the circuit detects the output voltage? or any sensor?
Old 2nd October 2015, 10:05 AM   #4
A schematic would help. I will be able to help further if you can post a copy or link.
Old 2nd October 2015, 05:21 PM   #5
Perry Babin is offline Perry Babin  United States
Post a photo of the drive/control section of the amp for that power supply.
Old 22nd October 2015, 02:27 AM   #6
thanks...but another problem exist, I will fix this first
JLHD 750Watts - high rail voltageHide this!Advertise here!
power supply rail voltage too high vintess Power Supplies 17 27th July 2015 10:56 AM
Cheap high voltage high wattage dual rail SMPS devices minimelkav Power Supplies 2 22nd August 2014 04:35 PM
Cadence ZRS8000d (C-Ver) High rail voltage. riveracc1 Car Audio 5 21st July 2014 08:54 PM
high rail voltage chip amps? mbates14 Solid State 15 30th November 2012 03:48 PM
Please suggest a high rail voltage (160V) amplifier Jay Solid State 19 3rd May 2012 07:32 PM
Copyright ©1999-2019 diyAudio
