Ill order the pf style then also the 100 ohm 2 watt resistor in the picture I am kind of curious because I am trying to locate the exact same style but it seems the alignment of the lines don't match up for the ones I am trying to match the only ones that match are 100R 100ohm 2 watt resistors but the color isn't blue like original in this amp I am trying to stay exact same because this amp is in really good shape just needs some mild repairs
Hey Perry I have a question for you these are alittle different in size hopefully they will be ok
Heres my question do you know if this style of capacitor has a certain polarity it has to go by in the board?
If so how do I identify on the board which way it goes the print on the board does not have any symbols heres a picture of the bad vs new
Hey Perry I replaced all PS Fets with the same model but they are PBF version replaced both of those film capacitors one for each transformer but when I power the amp up it powers on fine but will make a mid vacuum sound from it sounds like the transformers in which I have a working one here tested that with the same power source without a noise everything seems to be powering up fine the output relay clicks without tripping the protect light so I assume the outputs are not shorted since I last tested them.
Could shorted capacitors cause this I do know some looked alittle burned beings so close to the bad power fets that smoked they are 25v 3300uf
- General Interest
- Car Audio
- Memphis MC1.4000
