Rockford Fosgate Power T1500.1BD
Old 31st January 2015, 05:40 AM   #1
S Merlington is offline S Merlington  United States
Default Rockford Fosgate Power T1500.1BD
This amp has a strange problem..
When powerd up it has very low and distorted output ..
After about 45 mins of being on the amp will work normal again and have full output ..
It does this everytime its powerd up..
I checked all the regulators all test fine it has correct rail voltages ..
Anyone have any ideas on where to start looking?
Old 31st January 2015, 05:48 AM   #2
Perry Babin is offline Perry Babin  United States
Does it have rail-rail oscillation when it has low output?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 31st January 2015, 06:00 AM   #3
I just powerd it up and it has very low distorted output right now ..
So i tested for rail to rail oscillation and yes in getting rail to rail oscillation on the outputs
Old 31st January 2015, 06:46 AM   #4
Does it act any differently with the switches/pots in other positions?
Old 31st January 2015, 07:05 AM   #5
No acts the same
I tryed pushing on them and the board also no change
Old 31st January 2015, 07:56 AM   #6
I think audio comes in on the bottom rear-most pin on the driver board closest to the SMD regulator transistors. Do you have clean audio there?
Old 31st January 2015, 08:47 AM   #7
Yes i have clean audio on that pin comming ino the driverboard..
But if i start to increase the gain from the lowest setting it turns into a square wave
Old 31st January 2015, 01:36 PM   #8
Does it clip evenly top and bottom?
Old 31st January 2015, 01:39 PM   #9
Yes
Old 31st January 2015, 01:59 PM   #10
On the crossover board, do you have clean audio on the last two pins at the rear of the board and on at least one pin on the rearmost pair of pins of the front connector on the crossover board?
How long do you have to leave it off (after it begins to work properly) for it to not work normally when you power it on again.
Rockford Fosgate Power T1500.1BDHide this!Advertise here!
and, other rockford fosgate T1500-1BD josesony68 Car Audio 4 22nd October 2014 09:03 PM
Rockford Fosgate T1500-1BD S Merlington Car Audio 9 18th September 2014 04:14 AM
Rockford Fosgate T1500-1BD S Merlington Car Audio 4 24th February 2014 06:56 PM
Rockford Fosgate T1500-1BD S Merlington Car Audio 23 3rd May 2013 02:53 PM
Rockford Fosgate T1500-1bd - no output, no protect, no smoke whitejohnny Car Audio 32 11th April 2013 09:24 PM
Copyright ©1999-2019 diyAudio
