Crunch P1500.1
Crunch P1500.1
Old 7th August 2014, 02:17 AM   #1
S Merlington is offline S Merlington  United States
Default Crunch P1500.1
Anyone have a pic of the circuit board around the drivers in the output section of this amp?
Or know the value of C20?
Old 7th August 2014, 02:25 AM   #2
Perry Babin is offline Perry Babin  United States
It appears to be the same as the attached board. If so, it's a 470pf.
Old 7th August 2014, 02:27 AM   #3
Thank you for the info..
Can i replace it with a disk cap ?
Old 7th August 2014, 02:30 AM   #4
Yes. It's a ceramic cap (same as the disc capacitor).
Old 7th August 2014, 03:21 AM   #5
Ok replaced the capacitor..
Amp powers up but no sound..
I have + - 15 volts on power supply pins of all op-amps..
I have both positive and negative rail voltages 55 volts
I get rail to rail oscillation
I get audio on all op amps
but still no output..
Any ideas?
Old 7th August 2014, 03:25 AM   #6
If you have rail-rail oscillation, there's a problem.
Was that capacitor removed by someone or did it appear to be left out by the manufacturer?
Old 7th August 2014, 03:30 AM   #7
It was taken out by someone
Old 7th August 2014, 03:31 AM   #8
Are you sure that it's oscillating?
If so, remove the cap to see if it stops.
Old 7th August 2014, 03:44 AM   #9
Ok i will have to get some resistors tommrow morning this amp just self distructed on me..
I will replace all resistor that smoked and post back when i get it completed
Old 7th August 2014, 03:06 PM   #10
ultra is offline ultra
ultra's Avatar
If you need any pics,i have an identical amp on my bench.
Crunch P1500.1Hide this!Advertise here!
Massive Audio P1500.1 Amplifier amp it up Car Audio 7 20th February 2013 03:16 AM
Hafler P1500: how to make volume down to zero (∞db)? jackup Solid State 7 18th April 2011 10:28 PM
Hafler "Trans Nova" P1500 imix500 Solid State 25 5th May 2007 09:58 PM
The crunch meanman64 Car Audio 3 6th March 2006 05:18 AM
