JL 500/1
JL 500/1
Old 6th August 2014, 10:55 PM   #1
Triviumfan4 is offline Triviumfan4  United States
Default JL 500/1
Do these amps generally DC voltage across speaker terminals(25vdc).?
I'm also sure there's an issue because I have a square wave at speaker terminals as well.
Old 6th August 2014, 11:09 PM   #2
I'm assuming not,have some shorted MOSFETs and a handful of cracked resistors so far...
Old 7th August 2014, 12:25 AM   #3
Perry Babin is offline Perry Babin  United States
The DC voltage between the positive and negative speaker terminals should be less than 1v. The DC voltage from any speaker terminal and the main ground will be approximately 40v.
Old 7th August 2014, 12:29 AM   #4
Thanks for the reply.This is the first time on a jl class d.Changing drivers right now.I'm hoping it was just the FETs,drivers and a couple resistors.Might have to fire up your DVD on this subject lol.
Old 7th August 2014, 12:44 AM   #5
What's your thoughts on even a temp replacement of the 2n3906 drivers?All I have that's the same pinout is mpsa56...I have several others but not sure what would work even if I flipped the legs.A1266,a1023,a1015 and so on.
Old 7th August 2014, 01:43 AM   #6
Try the MPSA56s.
Old 7th August 2014, 01:46 AM   #7
I was thinking that was my best bet.Ill test it soon and well find out.Also I'm going to try it with 540N's.I've seen opinions back and forth.Guess well find out.
Old 7th August 2014, 01:49 AM   #8
I'd recommend the IRF3710Z as outputs if you have them.
For all JL500s, I've been using the 3205s in the supply and IRF3710Zs for the outputs.
Old 7th August 2014, 01:52 AM   #9
Trust me I've read your posts.I would use the 3710Z if I had them.I will order some so I have them.At this point I'm just trying to get it working to confirm I found all defective parts.
Old 7th August 2014, 01:58 AM   #10
The 540s are OK but if you have the 3710Z, use them.
JL 500/1Hide this!Advertise here!
JL 500/1 2many Car Audio 20 11th February 2013 12:23 AM
JL Audio 500/1 S Merlington Car Audio 4 7th September 2012 05:57 AM
JL Audio 500/1 mike49504 Car Audio 1 15th August 2010 10:02 PM
Jl 500/1 irf540n? mbates14 Car Audio 10 27th June 2010 12:14 AM
FS: JL 500/1 ($500 CAD located in GVA) Dynamix Lude Swap Meet 0 27th October 2004 04:21 AM
