T1500-1bdcp Rockford fosgate
Is the layout essentially the same as the non-cp amp (below)?
Something is differently wrong. With no input and a sub woofer connected the subwoofer will play a low frequency wave. Adjusting the crossover changes the frequency. If I touch the rca ground sheild the amp/ speaker cuts on and off making a lound noise.
I opened the amp up and noticed 2 of the large capacitors seem loose. If I hold/ move the 2 in a certain position the subwoofer stops playing that frequency.
2 of them were loose. I attempted to fix them. After getting it together it still has the same problem. The speaker moves in and out. If I touch the top of the large capacitor the speaker appears to stop moving.
I removed one of the caps. The board seemed fine. Ill try and pull the next one. Im a little frustrated. It took almost 30minutes to get one out. The solder did not want to flow
The board has pads and traces on both side.
If I touch the rca ground shields the speark will play a loud burst then turn off and on. I also noticed even without touch shields when I put my had close to shields it will effects the output also.
I am really lost and not sure where to look.
