T1500-1bdcp Rockford fosgate
Old 29th April 2014, 08:20 PM   #11
DREW028 is offline DREW028  United States
Send a message via AIM to DREW028
Something is differently wrong. With no input and a sub woofer connected the subwoofer will play a low frequency wave. Adjusting the crossover changes the frequency. If I touch the rca ground sheild the amp/ speaker cuts on and off making a lound noise.
I opened the amp up and noticed 2 of the large capacitors seem loose. If I hold/ move the 2 in a certain position the subwoofer stops playing that frequency.
Old 29th April 2014, 10:12 PM   #12
Perry Babin is offline Perry Babin  United States
Have you pulled the board to see if the solder connections are broken?
If so, you need to pull them to see how badly the board is damaged. Sometimes the arcing between the cap terminals and the board causes a fair bit of damage.
Old 30th April 2014, 01:58 AM   #13
2 of them were loose. I attempted to fix them. After getting it together it still has the same problem. The speaker moves in and out. If I touch the top of the large capacitor the speaker appears to stop moving.
I removed one of the caps. The board seemed fine. Ill try and pull the next one. Im a little frustrated. It took almost 30minutes to get one out. The solder did not want to flow
Old 30th April 2014, 02:18 AM   #14
Are the traces (not the pads) for the caps on the bottom of the board or on the top of the board?
If the vias are burned or broken out and the trace is on the top of the board, soldering to the pad on the bottom may not actually connect the cap to the circuit.
Old 30th April 2014, 11:28 PM   #15
The board has pads and traces on both side.
If I touch the rca ground shields the speark will play a loud burst then turn off and on. I also noticed even without touch shields when I put my had close to shields it will effects the output also.
I am really lost and not sure where to look.
Old 1st May 2014, 01:57 AM   #16
With the caps soldered in and the RCAs connected to a signal source that's grounded to the 12v power supply, does the amp play normally?
Old 1st May 2014, 05:11 AM   #17
Yes.
Old 14th March 2019, 05:57 PM   #18
rhempz01 is offline rhempz01  United States
Apologies accidental post. I jumped to this thread somehow?
T1500-1bdcp Rockford fosgateHide this!Advertise here!
Rockford Fosgate T-2500-1BDCP josesony68 Car Audio 15 6th November 2016 08:04 AM
Rockford Fosgate T1500-1 BD josesony68 Car Audio 42 21st May 2016 01:53 PM
Rockford Fosgate T1500-1BDCP ------ No Output spooney Car Audio 8 27th August 2013 11:46 AM
rockford fosgate T1500-bd RockfordFIx Car Audio 9 18th April 2013 12:12 AM
Rockford Fosgate T2500-1bdcp Parts rizzo30 Parts 2 4th January 2012 12:41 AM
Copyright ©1999-2019 diyAudio
