Hi, i got a used nakamichi dac 101, however it doesnt work properly, it just makes this ticking rumbling static noise, can anyone give advice on what to check?
Freeze spray will help you find leaky components. You power up your equipment and while listening to it, you start spraying IC's, output transistors, pre drivers until you find faulty component.
