Rockford Fosgate Punch 160.2
Thread Tools
Old 27th August 2013, 12:33 AM   #1
S Merlington is offline S Merlington  United States
Default Rockford Fosgate Punch 160.2
Is it D203 and D205 that disable's the protection in the right channel??
Or does anyone know which 2 i lift to disable it??
Amp has distorted output on the right channel
Old 27th August 2013, 02:17 AM   #2
seankane is offline seankane  United States
seankane's Avatar
Has the amp been previously repaired or is this how it came to you.
Just want some info before stating the obvious.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 27th August 2013, 02:32 AM   #3
It had blown power supply fets with i changed ..
It also had both 540's blown in both channels which i changed along with the drivers for the outputs..
Old 27th August 2013, 03:21 AM   #4
The right channel wont bias..
So its a bias issue..
I switched the MPS6521 I also switched Q208 and Q218..
with no luck..
where do i go from here?
Old 27th August 2013, 05:25 AM   #5
seankane's Avatar
If you don't have any shorted or open source resistors or if you did, you must have some damage in the protection circuit.
I am assuming you metered the resistors in the area around the blown outputs?
Check the 1A and 2A transistors as well.
If there is a fault sometimes the bias wont set properly.
What resistance do you get from source to drain on each of the outputs?
Its likely a shorted diode marked 5D.
Old 27th August 2013, 01:06 PM   #6
Perry Babin is offline Perry Babin  United States
If it's the same as the 160a2 (see photo), it's D202 and D204.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
  Reply to this post
Rockford Fosgate Punch 160.2Hide this!Advertise here!
Thread Tools
Rockford Fosgate Punch 150 mike49504 Car Audio 1 13th June 2012 04:20 AM
Rockford Fosgate Punch P3001 seankane Car Audio 3 26th October 2011 03:55 AM
Rockford Fosgate 160.2 MOSFETs? lukeman269 Car Audio 4 2nd September 2011 09:44 PM
Rockford Fosgate Punch 200a4 chipper Car Audio 7 26th March 2011 04:01 AM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 05:20 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
