With NO outputs in the circuit (<< VERY important), connect the side of the output filter inductor that's connected to the output transistors to the amp ground with a jumper. Make sure that there are no solder bridges between any of the output transistor pads. Does that allow you to see the high-side signal?
- General Interest
- Car Audio
- Audiopipe ap30001d
