Stetsom 6k2
Got this amp for repair with the entire power supply blown.
I suppose gate resistors are 3R9, but i need the value of R148 and R149 (not sure about exact number as the pcb is burned). These two resistors are used between the outputs of the totem poles (BD139/BD140), to ground.
Any help would be appreciated.
Put the 1K resistors in place, repaired the totem pole (one set of BD139/140 was blown, as well as the 4427). A schematic of the 5k2 shows this resistors as 4k7.
Then i checked all output fets with my component tester (in circuit) and all 8 seemed ok.
I powered the amp without the ps fets and i did see the 26k square wave developing slowly.
Soldered 2 dozens of new ps fets, clamped everything back to the heatsink and tried to power the amp with my 20A bench supply. It went to protect with 3 blinks on the power led indicator.
I thought 20A was not enough for the initial current of this big amp, so i changed to a 68A power supply.
During start up, the power indicator led is blue (ok) but the amp draws around 60A+.
I am afraid on damaging something and i remove the remote after 1.5-2 seconds.
Is this normal ?
well, no matter which transformer i unbolt its center tap from the 12V busbar, the current draw is the same.
I removed all 8 fep16dt-all checked ok.
Then bolted back all trafos and only kept the diodes out of the circuit.
Here is the very good waveform of both sides of gate resistors ( ps fets are in place).
Okay, this is the point I would pull the 2010's out(or 2110's) and put the diodes back in. If current draw is still normal, check the signal on pins 10 & 11 of the 4011's. (looking for a good pwm signal here). If current draw is still high with the 2010's out , check the bd139/bd140 pairs and also the 15volt zeners that tie the gates to the sources. (a shorted output isn't out of the question yet though)
