Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Thread Tools
Old 9th November 2021, 12:05 PM   #351
maximus is offline maximus  Scotland
Hi again Elvis,
The regulator drawing shows the 2.5v reference diode connected the wrong way around. The cathode should connect to the +ve rail of the regulator output. This must be an older drawing. Corrections have been posted earlier in the thread.
Paul
Paul Hynes
Old 9th November 2021, 12:12 PM   #352
elvispreasley is offline elvispreasley  Russian Federation
Thank you for pointing on that, Paul. I found the correction in the late thread before starting this project and rotated the diod the way how it should be.
Old 19th November 2021, 06:11 PM   #353
Originally Posted by Peter Daniel View Post
Just rotate the diode.
Hello, Peter. Have another question regarding your DAC. Am I understood correctly, that on CS8412 chip, the legs 24 and 7 + 24 and 8 are connected together with jamper? Or it's some mistake?
  Reply to this post
Pushing the limits of TDA1543 NOS DACHide this!Advertise here!
Thread Tools
FS: NOS TDA1543 DAC 2A3SET Swap Meet 0 24th March 2011 08:10 PM
Pushing Aleph P to limits - Passive Tri-amp Alves Pass Labs 4 12th September 2006 02:56 AM
TDA1543 and CS8412 NOS DAC Igla Digital Source 3 7th March 2006 08:27 PM
Nos Tda1543 Dac. IpsilonSound Digital Source 0 4th June 2004 07:25 PM
TDA1543 nos dac question... setmenu Digital Source 13 2nd June 2004 01:03 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
