Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 29th June 2020, 02:33 AM   #341
sthcoaster is offline sthcoaster  United Kingdom
Pushing the limits of TDA1543 NOS DAC
Been collecting parts for this DAC over a couple of years. Thanks to Covid I have time to put it together. I know from near the beginning of the thread PD’s schematic for the regulator (post#4) contains an/some errors.
I have tried to follow written descriptions to make the required corrections but can’t get my regulators to work as required.
The link to a corrected schematic here is broken. Can anyone help with this again?
Is it simply that the LMZ diode needs to be rotated 180’
Or are the positions of the 470r resistor and the diode also swapped?
Originally Posted by uncle_leon View Post
Hi Steve, here is the correct schematic:
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Go over every single connection one more time, make sure there's no solder bridges or bad joints, every part is right way round etc. If in doubt, check the respective datasheets for pin-outs. You will get there eventually, just be patient and methodical
Old 29th June 2020, 05:35 PM   #342
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Pushing the limits of TDA1543 NOS DAC Send a message via AIM to Peter Daniel
Just rotate the diode.
www.audiosector.com
Pushing the limits of TDA1543 NOS DACHide this!Advertise here!
FS: NOS TDA1543 DAC 2A3SET Swap Meet 0 24th March 2011 07:10 PM
Pushing Aleph P to limits - Passive Tri-amp Alves Pass Labs 4 12th September 2006 01:56 AM
TDA1543 and CS8412 NOS DAC Igla Digital Source 3 7th March 2006 07:27 PM
Nos Tda1543 Dac. IpsilonSound Digital Source 0 4th June 2004 06:25 PM
TDA1543 nos dac question... setmenu Digital Source 13 2nd June 2004 12:03 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
