Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 18th March 2020, 02:43 PM   #501
BigE is offline BigE  Canada
BigE's Avatar
Perhaps lifting the shield grounds from the case on the input side, but keeping them connected is correct? I'll make a drawing.
Old 21st March 2020, 03:24 AM   #502
BigE's Avatar
KOR952 WROTE below( I've tried it never better....., it's great for my Benz wood HO )
If there is more gain needed (+ 15dB), for instance when a Denon DL-103 is used, it is possible to change the second stage as follows.
R2 = R3 = 1k8
R4 = R6 = 1M
R5 = 100k
C2 = 3.3nF
C3 maybe the same (10uF) but may be changed to a 4.7uF
The gain of the first stage is R1 / cart. imp. x loss factor (due to the parallel RIAA cap)
For a DL-103 this will be 1620 / 40 x 0.9 = 36.45 x
The gain of the second stage is R5 / R3
For the original this will be 33k / 3.3k = 10 x
For the modified 15dB + version this will be 100k / 1.8k = 55.55 x
Output of a DL-103 with the original components = 0.3mV x 36.45 x 10 = 109 mV
Output of a DL-103 with changed components = 0.3mV x 36.45 x 55.55 = 607 mV
Difference in output is 14.9 dB
If you want less gain change R2 and R3 to a higher value, for instance 2.2k instead of 1.8k gives -1.74dB (0.818x) less gain.
RIAA filtering will not change while the values of caps and resistors are switched.
My 2 cents,
Ronald.
Old 13th May 2020, 12:33 AM   #503
BigE's Avatar
I wanted to revert to stock, and now the power supply is not working.
It showed +18.3 and -17.4 rails, I put in new opamps, it jumped around 0-10v, I turned it off, resoldered U1,Q2 Q1, Q2, and turned on again. Back to an unregulated 18 and 17 volts.
It seems the regulators have failed. The op amps were opez27.... I guess they are dead now too?
Any help getting this going again would be *greatly* appreciated, as this is my only phono section.
Old 13th May 2020, 01:32 AM   #504
BigE's Avatar
stable now. its all about poor measuring skill
15.2 and -15.4
Old 13th May 2020, 05:11 AM   #505
Temaad is offline Temaad  Australia
Default Will it suit a Accuphase AC-2
Hi, Have been looking for a MC phono amp that can work with my Accurphase AC-2, see specs
Output voltage: 0.18mV
Frequency response: 20 Hz to 60 kHz
Channel separation: 30dB
Channel balance: 0.5dB
Internal impedance: 4 ohms
Load impedance: higher than 50 ohms
Will this unit be OK, need at least 75dB of gain.
Cheers
Old 13th May 2020, 10:42 PM   #506
Also, I suppose I should ask, P
eter do you still have some boards.
Old 19th May 2020, 05:14 PM   #507
BigE's Avatar
I've been taking my stupid changes out of the phono section. Never again will I doubt the skills of the designer. Rookie egotistical mistake. I apologize for that.
I've learned enough to know I don't know very much at all. The power supplies are back to original and have reasonable voltages. One last change is to remove is the added 15 dB gain from a post earlier in this thread....
Can someone tell me please..... how can a circuit with a shunt regulated supply and no ground connection hum? Is this a floating circuit? If this is a floating circuit, a ground loop breaker, (two diodes back to back with resistor and capacitor between the power supply zero volt line and the earth ground), should not be needed. Is that correct?
Also, should the ground lug for the TT be isolated from the chassis and connected to earth ground or should the ground lug be attached directly to the chassis which is already connected to earth?
I see about 3 mV of noise on the output with a scope attached.
Old 20th May 2020, 12:44 PM   #508
BigE's Avatar
Looks like this is headed to the bin
Old 23rd May 2020, 09:59 PM   #509
BigE's Avatar
fixed!
There are quite a few vias under parts. If you like to remove/replace a lot, you run the risk of damaging these vias. You then need to be creative.
Old 23rd May 2020, 10:26 PM   #510
BigE's Avatar
If you are going to build this, my recommendation is to match R2 and R3, the resistors between the Op amps.
Also, I believe that the sonics are related strongly to the quality of the caps. I tried a few, and in the 0.1 uF position, to my ear, Vcap is stellar
The Phono StageHide this!Advertise here!
NS-10 phono stage ponger Pass Labs 9 28th March 2011 08:57 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
phono stage east electronics Tubes / Valves 20 24th March 2008 08:22 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
