Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 2nd February 2014, 09:16 PM   #1751
Joerytech is offline Joerytech  Netherlands
Then I don't know, maybe peter has an idea. to bad for you, I'm really enjoying his amp. and the previous amp I used seemed not to be the worst and peter's is way out of that's league .
Old 2nd February 2014, 09:22 PM   #1752
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
Originally Posted by Xerxes75 View Post
My old standard LM3886 gives better results...
How is it built then?
www.audiosector.com
Old 2nd February 2014, 09:31 PM   #1753
Xerxes75 is offline Xerxes75  Netherlands
The lm3886 is from chipamp.com is also dual mono and uses 2x25v transformer and the usual chipamp power supply and only the standard parts are used.
I see a lot off builders using caps on the input, could this be the answer?
Old 2nd February 2014, 09:45 PM   #1754
Mmmhh i checked it and all seems fine, and as I play my lm3886 and ta2020 with same speakers in the same room the bass sounds more alive and much deeper. Maybe Peter Daniel has an idea?
The overall sound is extremely pretty...a better bass would make it complete..
To bad you live far from me, if you want your very welcome to come over to listen here in Eindhoven
Old 2nd February 2014, 09:56 PM   #1755
Listening to Armin van Buuren now, max volume, great bass, definition, simply WOOWWW.
Old 2nd February 2014, 10:03 PM   #1756
In that case put the similar caps in LM4780 and you should receive similar results. Previous pic shows that larger caps will fit on rectifier board.
Caps on the input are only needed when source shows DC offset, otherwise, in most cases, they will degrade the sound.
www.audiosector.com
Old 2nd February 2014, 10:18 PM   #1757
But so much influence??
Old 3rd February 2014, 07:53 AM   #1758
Thanks for your replies, I will try the swap with the parts.
Eindhoven is a bit far otherwise I would have a listen but thanks anyway!
Old 3rd February 2014, 10:08 AM   #1759
R.I.P.
the amp float and the chassis and copper bar will never touch the floor.
The pics in post1738 show the copper bar is bolted to the thick aluminium Chassis. It is not floating. That aluminium is you heatsink.
Have you inserted Thermal Paste into the joint between copper and aluminium to reduce thermal resistance. Why only 2 bolts? Three would be better, five are probably good enough.
regards Andrew T.
Old 3rd February 2014, 11:54 AM   #1760
I said the AMP is floating, not the copper bar.
Its bolted with 3 M5 bolts to the aluminum chassis.
I did not use paste because I'm not sure the paste can cause electrolytic corrosion, Two different metals with fluid in between can cause the least noble metal (not sure you say it like that in English) to corrode away.
3 bolts are enough as the metal strips are thick and will only very slightly bend.
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
