Ladegaard tonearm - the real DIY winner
Old 31st December 2007, 02:05 PM   #81
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Thi was " in the air" a few years ago...
http://www.newwayairbearings.com/Fam...Air%20Bushings
Old 1st January 2008, 05:48 AM   #82
Nanook is offline Nanook  Canada
Nanook's Avatar
Default for tubing I was commenting on...
... the actual metal tubes , as per the post made by AuroraB
eg:
1/4"OD to fit into 5/16" ID.
of course the link made by AuroraB is a complete solved solution. I wonder if any have had an idea o check the costs...
stew
stew -"A sane man in an insane world appears insane."
Old 1st January 2008, 01:08 PM   #83
el`Ol is offline el`Ol  Germany
The Ladegaard looks like an elegant solution, bearing in mind that DIY can also look this way:
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Old 1st January 2008, 01:44 PM   #84
AuroraB's Avatar
For those interested, - the price mentioned earlier, was appx 240$ for the air bearing combo.
It is discussed in this post
http://www.diyaudio.com/forums/showt...583#post153583
Old 1st January 2008, 10:23 PM   #85
woodturner-fran is offline woodturner-fran  Ireland
AFAIK, that TT in acrylic was at a high end show in Munich (can you imagine moving that thing!) and uses a linear tracking arm that floats in a bath of water. To adjust VTA, you add more or less water!
Actually seems like a pretty neat idea!
Fran
Old 2nd January 2008, 01:28 AM   #86
AuroraB's Avatar
Somewhat borig, only playing "Water Music" ?
Old 2nd January 2008, 05:21 AM   #87
Do you think cloning this would be within reach for a DIYer?
Old 2nd January 2008, 05:36 AM   #88
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Yes. I own that model, Clearaudio Tangent, and I've been thinking about it just for kicks, not that I need to.
FWIW, I've never had a problem since owning it years back.
Old 6th March 2008, 12:51 PM   #89
webby is offline webby  United Kingdom
Smile Another Ladegaard floating
Hi All,
I now have my first prototype arm working! Thanks to Kvap9 for all the advice.
It's just sat next to my TD321 for now, but i have started my own TT based on some leftover walnut for the plinth, the Algar_emi / Mark Kelly dc motor kit and a VPI scout bearing and platter.
First impressions are very good, but i wanted to get some advice on what to try next.
I used some carbon for the tube and a cheap headshell glued to the end, see photo. I soldered the earth wire to the p mount connector on the headshell, but the hum is terrible when connected. What is the correct point to connect earth?
eventually i want to use an arm made from walnut and be one piece.
I was going to use an empty 1ltr plastic bottle for the surge tank, is this ok, or does it need to be very stiff?
Any other advice will be most welcome
Cheers
webby
Old 6th March 2008, 12:53 PM   #90
Default Another picture
This is what i hope to achieve!
Ladegaard tonearm - the real DIY winnerHide this!Advertise here!
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 5 31st May 2015 03:55 AM
Airbearing tonearm design (not Ladegaard) koyaanisqatsi Analogue Source 9 27th October 2006 06:51 PM
And The Winner Is............................. Audiofanatic Digital Source 30 25th June 2006 06:24 AM
Ladegaard peterr Analogue Source 57 20th April 2005 02:26 PM
Copyright ©1999-2019 diyAudio
