The Phonoclone and VSPS PCB Help Desk
Old 2nd December 2015, 11:19 AM   #3301
mimmo is offline mimmo
mimmo's Avatar
Hi there!
I have a simple question:
What is the hole size on the VSPS pcb for the resistors? I plan to use component sockets for some of the resistors so swapping them would be done without soldering if needed.
Apologizes if this has been answered somewhere...
Thanks,
Mikko
Old 2nd December 2015, 11:43 AM   #3302
rjm is online now rjm  Japan
Richard Murdey
rjm's Avatar
Resistors are generally 0207 packages, 0.4" 10 mm pad-pad, 0.032" 0.8 mm drill, but through-hole plating means the actual hole diameter is a little less than that.
RJM Audio | phonoclone.com
Old 2nd December 2015, 04:14 PM   #3303
Bibio is offline Bibio  Scotland
Bibio's Avatar
this is the solution i came up with for swapping out different value resistors.
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Old 2nd December 2015, 07:30 PM   #3304
folkdeath95 is offline folkdeath95  France
folkdeath95's Avatar
Nice.
I plan to use that kind of terminal: Barrette tulipe - 1x40 points droite - Barrettes tulipe.
Your solution looks smarter. What's the name of these terminals?
Petite Onken/Altec 414-8B+Faital HF10AK/Audio Pavillon MA600; Firstwatt Aleph J Clone; Firstwatt B1 clone; Technics SP10; Sphinx Myth9 MkII+Parasound DAC2000
Old 2nd December 2015, 07:35 PM   #3305
Bibio's Avatar
they are just your common pin strips and headers. i'll try and dig the details out later but i posted the mouser item numbers earlier in the thread (i think)
Old 3rd December 2015, 02:37 PM   #3306
WntrMute2 is offline WntrMute2  United States
WntrMute2's Avatar
Originally Posted by folkdeath95 View Post
Nice.
That's what I have been using. Works fine.
Old 3rd December 2015, 02:42 PM   #3307
Bibio's Avatar
just dug out the pin strips. the ones i used were Harwin M20
Mouser part#
5 way wire housing, 855-M20-1060500
40 way breakable pin strips, 855-M20-9734045
Crimp terminals, 855-M20-1180042
when using the pin strips you can remove 3 pins in between with pliers (they slide out easily) to keep things square.
Old 3rd December 2015, 03:30 PM   #3308
R.I.P.
I leave the extra pins in place and add extra receptacles to the plug.
That gives a stronger mechanical grip for plug to socket.
I also pair off two pins and two receptacles so that it has double the contact points for each signal.
An example was for the NX PCB.
The three pins @ 0.1" were standard. Two Signal Return and one Signal Hot.
I solder on a 6pin DIP Header, so that the PCB now had 4 Signal return receptacles amd two Signal Hot. The 6pins are on a grid 0.2" wide by 0.1" deep.
I used a star quad cable to a 6pin DIP plug. The two signal Hot wires went to the two middle pins.
The two Signal Return went to the two diametrically opposite Return pins. That gave my connection 4 sliding contact points for the Hot and 4 sliding contact points for the Return. And 4 more sliding contacts to increase the mechanical grip.
regards Andrew T.
Old 3rd December 2015, 04:57 PM   #3309
Bibio's Avatar
great Andrew but there are only two holes on the PCB :-) unless you slide the other pins up and off the board.
Old 3rd December 2015, 04:58 PM   #3310
WntrMute2's Avatar
Not following this. Can you post some pictures?
The Phonoclone and VSPS PCB Help DeskHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
