Low noise Balanced MC Pre
Thread Tools
Old 1st December 2021, 02:59 PM   #261
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Thatís great to know Jack. Iím about to order a few more - hopefully Iíll get the same results.
Bonsai X-Altra MC/MM preamp http://hifisonix.com/x-altra-phono-eq-preamp/ Ground Loops http://hifisonix.com/ground-loops/
Old 1st December 2021, 03:40 PM   #262
syn08 is offline syn08  Canada
syn08's Avatar
Originally Posted by Hans Polak View Post
In the TranBal Hfe and Vbe are IMO not very relevant
True but otherwise Hfe is very important in bipolar low noise circuits, it defines the input current noise. Hfe was the beauty of the now extinct low noise bipolars like 2SC2547/2SA1085; they combined low Rbb (under 2 ohm) with very high Hfe (1000 was very common). At 15mA, this leads to 0.7pA/rtHz, while with the ZTX devices one cannot hope for anything lower than 2.5pA/rtHz. Not important for a few ohms of source impedance, but for a high level MC cartridge this could be very important in the noise budget.
Old 1st December 2021, 04:50 PM   #263
Bonsai's Avatar
Here is the PCB so far - still some more refining to do but nearly there. board is 160mm x 110mm.
Remote +-15V PSU is also finished. After that the rear panel will be done for those that want to use a Modushop housing (through the rear panel away and use the PCB rear panel - same as X-Altra).
Old 1st December 2021, 09:06 PM   #264
Bonsai's Avatar
Remote PSU. This slides into a small Modushop housing and the rear panel is also a PCB
Old 1st December 2021, 09:43 PM   #265
Bonsai's Avatar
Project on hold until next Tuesday as I am away.
  Reply to this post
Low noise Balanced MC PreHide this!Advertise here!
Thread Tools
true balanced, fake balanced and other balanced amps studiophone Solid State 4 6th May 2020 07:58 AM
ultra low noise power supply and low noise amplifier ambrosia168 Power Supplies 8 13th October 2017 03:43 PM
Low noise, low microphony, low hum valves MarcelvdG Tubes / Valves 38 28th January 2013 09:42 PM
preamp supply LOW power LOW noise LOW cost drdagor Power Supplies 1 14th September 2010 12:39 AM
Low Noise Balanced Microphone Preamp (PCB also). Ayne Solid State 11 22nd April 2007 04:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
