Audio Reviewers, Are They Serious?
Thread Tools
Old 13th October 2021, 08:46 PM   #81
academia50 is offline academia50  Argentina
Originally Posted by academia50 View Post
..... money is not a problem for me....
You say " All well and good for you. "
I'm glad you understood my irony / sense of humor !
Old 13th October 2021, 11:48 PM   #82
wiseoldtech is offline wiseoldtech  United States
wiseoldtech's Avatar
On that mention of the broken Shure stylus....
I've pretty much be proactive and protective with my stereo.
Back when I had a lovely brand new Dual 1229 fitted with a Shure V15 Type2 Improved, I always dropped the stylus guard down after using the turntable.
Bohemian Guru sagacious, professional.
Old 14th October 2021, 02:26 AM   #83
Yes, Shure's top-of-the-line models incorporated that handy needle guard, and the Type IV added a cleaning brush.
Regarding the sound, my preferences were for Stanton within the MM, I had in use the 681S and two 881S, the latter was clearly superior - for me - to the Shure Type III, especially in the low range. I can't comment on Type IV, I had already retired from the audio business when it went on sale, although it always continued to be my favorite hobby.
These are my two current turntables, I have built a selector box for them, used low capacitance teflon cable and gold plated RCA terminals.
(photos taken from the web)
File Type: jpg a4f2aeb6-b588-4141-9660-1a5a815397b5.jpg (43.5 KB, 98 views)
Old 15th October 2021, 06:39 PM   #84
Originally Posted by Bonsai View Post
High end audio companies claiming to be using tubes because they sound superior have been known to just run the heaters and use a NE5534 to do the donkey work quietly tucked away in a corner under the PCB.
Here I am talking about Project Tube Box S2, do you know ?
Old 15th October 2021, 06:43 PM   #85
Just sayin'
Can you give precise examples?
Brand , model ?
It is known is a very ambiguous phrase, it does not mean anything in a serious debate ....
Just sayin' ....
Old 15th October 2021, 06:48 PM   #86
That you prefer SS does not disqualify the tubes. I can give you many examples that will pass the rag to many projects, brand or DIY .....
Old 15th October 2021, 06:52 PM   #87
Galu is offline Galu  Scotland
Originally Posted by Galu View Post
The 18V DC supplied by the outboard supply is converted electronically to the higher DC voltage (at least 100V) required by the anodes of the ECC83s.
Commentators should not confuse the $400 Pro-Ject Tube Box S2 with some cheap Chinese preamp where the valves are there simply for show!
It would seem, academia50, that some commentators do not bother to follow the thread from its beginning.
Old 15th October 2021, 06:53 PM   #88
Nice turntables, by the way!
Old 15th October 2021, 07:10 PM   #89
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
I have absolutely nothing against tubes whatsoever. My skill set lies with SS and thatís why I donít design with them.
Bonsai X-Altra MC/MM preamp http://hifisonix.com/x-altra-phono-eq-preamp/ Ground Loops http://hifisonix.com/ground-loops/
Old 15th October 2021, 08:35 PM   #90
Galu, that is clear, it is easier to look for "hair to the egg" and join the devaluing general opinion.
Very unfortunate and common in forums, by the way.
Notice that I, and like you and so many others, let obvious things happen, to keep the thread alive, for example, a few days ago I read a comment about the benefits of a German TT brand that "totally decouples the automatic system when it plays vinyl "... in truth, all automatic or semi-automatic TTs do it, otherwise it would be impossible to reproduce vinyl! But in order not to undermine the appreciation that user feels for his revered turntable, I closed my mouth, as many would have to do on other occasions.
Audio Reviewers, Are They Serious?Hide this!Advertise here!
Thread Tools
What's with audio reviewers and their cats? kaytata Music 3 26th July 2019 07:11 PM
How to design speakers for Stereophile reviewers eriksquires Everything Else 71 31st May 2016 12:39 AM
An interesting web page: Reviewing the 'Reviewers' gaetan8888 Everything Else 1 27th May 2010 09:55 AM
added 9 more gurus, incl: John Marks, Andy G and other reviewers. Pjay Multi-Way 0 9th March 2005 05:27 AM
Reviewers? Val Lewton Pass Labs 0 17th October 2002 07:21 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
