Akai AP-007 or Technics SL-5
Thread Tools
Old 12th July 2021, 05:45 PM   #11
SalveTitus is offline SalveTitus  Netherlands
Originally Posted by safe1 View Post
I found a similar motor but if I'm interpreting its specs correctly it spins at 3 rpm.
Now, yours says 4/4.8 rpm . I guess that would be equal to 0.833 rpm ? (assuming that when they type 4/4.8 in the specs sticker, they mean a division of 4 by 4.8 ??? )
Japan / Nidec Servo D-5N Synchronous Motor 1.5W CW 3 rpm | eBay
I have hopes you can find an even closer match?
I ordered it! Tnx
Old 21st July 2021, 03:41 PM   #12
safe1 is offline safe1  United States
safe1's Avatar
So, did that similar motor found on ebay work for you?
(adding photos of the replacement motor for future reference)
Old 22nd July 2021, 05:24 AM   #13
Iíll let you know as soon as I received it and fitted it! Itís still underway (on the last leg now, from customs to my house;-) I am very curious
Old 28th July 2021, 11:34 AM   #14
It arrived,iíll try to insert it one of these days! It really has exactly the same dimensions, only the shaft is shorter, hope that wonít be a problem. I pried the old motor open, cannot be fixed as I thought, see photo, the last gear wheel is cracked.IMG_7989.jpg
Old 30th July 2021, 04:04 PM   #15
And it works! Many thanks @safe1 for finding the motor and others for kind advice! Now the Akai is ready for the next 40 years ;-)
Old 1st August 2021, 06:10 AM   #16
safe1's Avatar
Great news enjoy your AKai !
  Reply to this post
Akai AP-007 or Technics SL-5Hide this!Advertise here!
Thread Tools
The SA 007 amp hollowman Tubes / Valves 8 10th June 2019 04:21 PM
PPi ICE 7000.1d driverboard supply CHAS-007-01 joselorenzo Car Audio 4 21st February 2019 06:30 AM
Vestax PMC 007 schematic lukealdred Chip Amps 3 29th April 2011 11:41 AM
FS Magnequest FS-007 Jozef Swap Meet 10 3rd July 2010 10:11 AM
Luxman A-007 --- Schematic? Oery Solid State 0 14th January 2009 06:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
