Recently was cleaning out my father in-laws basement and found a Mark Levinson JC-1DC Moving Coil Cartridge Preamplifier (Serial# 0063) that he had. Found this forum based on searching the web and was hoping that someone here could give me more info on it. Don't believe I have the equipment to test it, but based on putting batteries in it and connecting a couple speakers to the output jacks, it seems to work. Does look like the battery holder may have been replaced at some point or re-soldered. Is it worth anything, and if so, what would be a reasonable amount I could get for it, since I really can't fully test it?
Really appreciate any help!
Cant open up your links but it doesn't matter I have seen the internals.
Its the battery version of the AC version power supply ---IF and that means you can play music using it when you say "works " then you can sell it for quite a bit of $$$ but if you are going to advertise it for sale as "working " you better be sure of your facts before somebody sues you for a faulty unit.
A guy in NJ is selling a working AC version for $1300 , yours IF fully working would be much lower than that but say $500+ , try and prove it works okay US laws on bad selling practices are strict.
All one needs to do is copy the link and then paste the link into a new browser window..Cant open up your links but it doesn't matter I have seen the internals.
That's it..
Thanks for the replies! Appreciate it.
This might be a silly question, but is there an easy way to test it? I don't have access to a phono player, but I would think there is some way I could test the functionality of it using possibly a computer, iPod, etc.. I definitely want to sell it so someone can get some use out of it, but would like to know if it actually works before I put it up on eBay.
That's it..
No as easy as you think , I got a new open source browser that opens most DIY Audio pictures but some have tracking links built in to the apps they use which are blocked by my apps I am not willing to disable my security apps for a picture only for DIY Audio itself.
Coding is contained in some apps that even clicking on them gets a tracking cookie or one of the newer deeper ones into your PC.
I want to know the differences (concerning circuit topology) between the modules for JC-1 - go to second picture under
https://theaudiostandard.net/thread/4790/history-mark-levinson-audio-systems
and JC-1DC which is obviously in most cases in a not potted version in use as I note in the meantime.
But I had the potted version of the JC-1DC approximately 20-25 years ago (maybe the first charge of it - manufactured in the same years and the same kind than the potted JC-1 module), which I had sanded down on the soldering side to create the circuit diagram so that the conductor tracks just appeared.
Schematics of JC-1DC which I have created at those days are to find under
https://www.diyaudio.com/community/...etween-mark-levinsons-jc-1-and-jc-1dc.243267/
I think, the mostly to find not potted PCB version use the same circuit topology.
There is a third version of this head amp: the JC-1AC - go to
https://totalaudio.net/entry/Mark-Levinson-마크-레빈슨-사의-MC포노-헤드엠프-JC-1AC-입니다-레모버젼-RCA버젼
There are probably even more JC-1 versions.
- Analogue Source
- Mark Levinson JC-1DC
