Luxman EQ-500 voltage conversion
Thread Tools
Old 6th May 2021, 12:20 PM   #1
SHR66 is offline SHR66
Default Luxman EQ-500 voltage conversion
Hello Everyone,
Does anyone know how to convert a Luxman EQ-500 phono amp with AC mains input of 100v 50/60Hz to 230v 50Hz?
Can it be done by internal DIP switches/fuse change/basic rewiring or does it need soldering and/or major part replacement (such as transformers)?
Thanks in advance.
Old 6th May 2021, 12:39 PM   #2
picowallspeaker is online now picowallspeaker  Italy
picowallspeaker's Avatar
On this page it's written like this:
Power supply 230V~(50Hz) / 115V~(60Hz)
EQ-500 | PHONO AMPLIFIERS | PRODUCTS | LUXMAN | Seeking higher sound quality
..but if you say 100 V it's for Japan only, I guess.
there’s no staying at home when you do not have one
Old 6th May 2021, 05:32 PM   #3
duncan2 is offline duncan2  United Kingdom
Manualslib has a circuit diagram but it only shows a single input primary winding .
Old 6th May 2021, 05:35 PM   #4
Thanks. Will try and get the diagram from Manualslib.
  Reply to this post
Luxman EQ-500 voltage conversionHide this!Advertise here!
Thread Tools
500 x2SC1844. 500 x2SA991 new old stock 2SA991 Swap Meet 0 16th November 2016 08:13 AM
PE Bash 500 conversion for 230V 50Hz rhapsodee Class D 2 26th June 2014 04:28 PM
Celestion MD-500 and MF-500 peterdav Multi-Way 1 9th December 2010 09:29 AM
I need Crown XS-500 service manual or schematic (XS-500, -700, -900, -1200) timbert Solid State 0 30th March 2009 06:52 PM
FS: JL 500/1 ($500 CAD located in GVA) Dynamix Lude Swap Meet 0 27th October 2004 03:21 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
