Problem with Pioneer TX-608 Tuner (1980)
Thread Tools
Old 5th May 2021, 02:12 PM   #21
Vintagelover is offline Vintagelover  Belgium
The problem is solved! You're the best!
I'm very happy with my fixed vintage radio.
Repairing things can be very satisfying
Long live diyaudio!
Vintagelover
Old 5th May 2021, 06:28 PM   #22
anatech is offline anatech  Canada
anatech's Avatar
Hi Vintagelover,
Everyone tries to be helpful.
What part # did you use?
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 5th May 2021, 07:04 PM   #23
My local store didn’t have a TIP41A, B or C. But he came up with a BD243C. That did the job.
Old 5th May 2021, 07:15 PM   #24
anatech's Avatar
Hi Vintagelover,
That part has very low gain. Probably overkill for the job. If you do run into performance issues, like poor regulation or excessive supply noise, try a TIP41 or one of these (or similar). I did a search on Digikey and you now have time to order something more appropriate. The device is fine at a 3 amp rating for collector current. 1 amp would do it, but I'm leaving room for charging capacitance when you switch on. A TO-126 part might possibly work as well, but heat dissipation would be your limiting factor.
-Chris
Old 7th May 2021, 06:32 PM   #25
Thank you, I’ll look into it
  Reply to this post
Problem with Pioneer TX-608 Tuner (1980)Hide this!Advertise here!
Thread Tools
Pioneer SA 608 Low volume on right chanel bobyblg Solid State 3 12th January 2021 11:43 AM
Pioneer SA-608 Blown Fuse Vintagelover Solid State 11 14th November 2020 06:25 AM
Onkyo TX-SR 608 start problem sippo Solid State 1 30th December 2015 12:07 PM
Pioneer SA-608 phono stage hum JohanH Solid State 6 22nd January 2015 12:09 PM
pioneer sa 608 amplifier peter hawthorne Solid State 2 4th October 2007 02:30 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
