What cartridge upgrade from a Shure V15 v-mr ?
Thread Tools
Old 14th January 2021, 08:15 PM   #151
academia50 is online now academia50  Argentina
Originally Posted by Bonsai View Post
I have one (not in use now since Iím using a Denon DL103 MC on an SME 3009 II).
I was very close to acquiring the famous "best buy in MC" until I read this ....
Denon DL-103 - The most overrated MC of all time!- Vinyl Engine
Could you give us your opinion ?
Old 14th January 2021, 08:24 PM   #152
el donkey is offline el donkey  United Kingdom
MMC20E which was the next stage up.
Old 14th January 2021, 08:50 PM   #153
The B&O MMC20EN which was the next to top model at the time.
This one needs a clean.
Old 14th January 2021, 09:42 PM   #154
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
@academia50
I would not take opinions that are based on subjective assessments too seriously - including mine.
However, a plot of the cart output came in the box - its flat out to 20 kHz and the channel balance is outstanding for an electro-mechanical device.
This says it all:-
“Hi Fi World, by the way, has the 103/103R on their list of most recommended cartridges (November 2006 issue), not that that really means much to me.”
I used a Hanna SL for a few weeks and that was very good (highly rated by Keywood) but it cost £999 vs the DL103 at about £250.
The DL103 has been around in various guises since the early 1960’s and has stood the test of time. I doubt there is a better MC for the money.
I’m using an SME on a Michel Gyrodec and a self designed pre (different to the self-designed one I used on the Hana SL)
Bonsai X-Altra MC/MM preamp http://hifisonix.com/x-altra-phono-eq-preamp/ Ground Loops http://hifisonix.com/ground-loops/
Old 14th January 2021, 10:22 PM   #155
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
To me the DL-103 is the flathead ford V8 of the cartridge world and popular because you can mod it for much better performance, so people do.
Three years ago i should have been sensible and just got my Benz wood retipped (about £200) and got an AT150MLx for MM duties, but I sold the Benz and went on a spree. My mid life crisis as I don't have a garage for a sports car at the moment
My next impulsive sillyness will be a rebuild of a Mk1 Ortofon MC20. 0.07mV output as new with 2.5Ohm coils. It'll be less when finished.
Old 14th January 2021, 11:05 PM   #156
Bonsai's Avatar
That MC20 is about 30uA output.
That’s a high output cart in my book
Old 14th January 2021, 11:07 PM   #157
billshurv's Avatar
That's why I got it
Old 15th January 2021, 12:05 PM   #158
My B&O cartridge adapter arrived this morning.
I will give it a test later and report back. I am not expecting to be knocked over but it will be interesting.
Old 15th January 2021, 12:11 PM   #159
Also, having weighted up my options I am going to make some updates to the LP12 in the near future.
1. Stiffer subchassis
2. Update the bearing
3. Given reports a stiffer top plate makes gains but at quite an expense I may op to add some T section ribs at random angles to the underside. I just need to check clearance.
4. I will add a removeable beech wood cross brace to the underside. I currently run it with no base board in place.
I will keep looking out for alternative carts to try but feel this will gain me more initially.
Old 15th January 2021, 07:08 PM   #160
Ok, now listening to the first of the three B&O cartridges I have.
They are a lot lighter than the V15.
Needed to put my heavier anti skate weight back on.
Counterweight quite far in but I recall I have the heavier option on my 9cc arm.
Setting the arm level did not sound best, now have the base of the cart about level. I will try more nose down after.
Running the mmc20e first. Wasn't particularly impressed via headphones.
Ran for a side while main amps warmed up.
First impression is it does not have the weight of bass to match the V15. Speed though is there.
This cartridge though has a trick. Its throwing a very wide sound stage and 'hanging' sounds in the air.
I am going to listen further before trying another.
I still have my pot fitted to adjust resistor loading. Reading though these may need more capacitance than I am running.
What cartridge upgrade from a Shure V15 v-mr ?Hide this!Advertise here!
Thread Tools
Is the Shure V15 IV a 'quiet' cartridge? Kay Pirinha Analogue Source 12 20th September 2017 03:31 PM
For Sale: Shure V15 Type III Cartridge with NEW Ed Saunders Stylus iamdarren73 Swap Meet 11 21st May 2016 11:20 AM
Transcriptors Saturn turntable for sale + vestigial + shure V15 Magnetmaz Swap Meet 6 29th July 2004 05:07 AM
Shure V15 Type III or Grado Gold Phono Cartridge mig-ru Analogue Source 31 23rd March 2004 08:45 PM
Shure V15 stylus replacement problem namui Analogue Source 0 15th September 2003 11:23 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
