What cartridge upgrade from a Shure V15 v-mr ?
Thread Tools
Old 13th January 2021, 06:58 PM   #121
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Originally Posted by el donkey View Post
Now all the talk of Linn and its march forward over the years has me enquiring on the new Karousel bearing vs a MOBER chassis !
As you've probably figured out, the Karousel bearing kit is 750. If you're going to keep your stock steel sub-chassis, I wouldn't bother.
jeff
Old 13th January 2021, 07:06 PM   #122
el donkey is offline el donkey  United Kingdom
It will work with Cirkus (100 used) / Majic (350 used) /Kore (800 new) or a MOBER (poor mans Keel alloy (390 new) Plus the 750 for the bearing kit
Or another option is the all in one MOBER chassis plus a used Cirkus for less money (550)
Old 13th January 2021, 07:44 PM   #123
sser2 is offline sser2  United States
I don't know, maybe there is Jico that makes tapered boron cantilevers for AT, but it is sure not the same Jico that makes replacement needles for almost everything.
Old 13th January 2021, 10:21 PM   #124
billshurv is online now billshurv  United Kingdom
billshurv's Avatar
It's the same Jico, in the same way that the Evanston factory used to produce delectable thin wall Be cantilevers and DJ carts with bonded lumps of coal on the end. You try and cover as much of the market as you can when you tool up.
Old 13th January 2021, 10:26 PM   #125
billshurv's Avatar
For El Donkey, a couple of cclose ups of my MMC2. They will never make them like this again! photo courtesy of Ray Parkhurst who was checking the wear on it.
Note there is an odd cut on the diamond but the wear surfaces are in great condition as it was used on a linear tracker.
Old 13th January 2021, 10:48 PM   #126
Those are good images. I shall have to have a play around myself at some point. Be interesting to compare that to the 3 I have for cut (if they remain in good order).
I have a macro lens. I'd guess that first image was focus stacked.
I also have a low cost digi microscope which took exceptional close ups but the drivers were not updated.
I can still get it to work but not as nicely as it did with the originals.
Old 13th January 2021, 10:53 PM   #127
billshurv's Avatar
Those were all done on a serious focus stacking rig*. Ray specialises in photographing coins MacroCoins Home but has started doing stylii as well for the challenge. He's dispelled a few myths about stylus wear on his threads on Vinyl Engine. One day I will have a suitable rig for this, but right now no where to put one.
*P.S. well done for spotting that.
Old 13th January 2021, 11:28 PM   #128
Guerilla is offline Guerilla  Denmark
Is that ear-vax I see on the first picture?
Cheers!
Old 13th January 2021, 11:32 PM   #129
billshurv's Avatar
No it's glue. It's a laser drilled sapphire tube and then the slot for the diamond is also laser cut and glued in. That is not the neatest gluing I have seen on a B&O stylus, but it's MINE.
Old 14th January 2021, 07:08 AM   #130
You are just awaiting an adapter from the US before testing the MMC2 on another arm then?
What cartridge upgrade from a Shure V15 v-mr ?Hide this!Advertise here!
Thread Tools
Is the Shure V15 IV a 'quiet' cartridge? Kay Pirinha Analogue Source 12 20th September 2017 03:31 PM
For Sale: Shure V15 Type III Cartridge with NEW Ed Saunders Stylus iamdarren73 Swap Meet 11 21st May 2016 11:20 AM
Transcriptors Saturn turntable for sale + vestigial + shure V15 Magnetmaz Swap Meet 6 29th July 2004 05:07 AM
Shure V15 Type III or Grado Gold Phono Cartridge mig-ru Analogue Source 31 23rd March 2004 08:45 PM
Shure V15 stylus replacement problem namui Analogue Source 0 15th September 2003 11:23 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
