Hi, so ive heard if i connect L and R together without resistor it starts fighting eachother . People told me that its almost the same like shorting two amplifier outputs together, it will work but not long .
So my question is what kind of resistor values i should use ? Also im putting 10k pot between the source and amplifier input .
Source is a bluetooth module and im using class d tpa3116 100w mono amplifier board, gonna make a bluetooth speaker. I don't need a stereo sound for my speaker because you couldnt even tell the difference 10m away from the speaker . Im using two stereo bookshelf speakers .
Thank you guys ! Much love
2.2 kohm would be a reasonable value: not too much voltage loss with the 10 kohm potmeter and high enough to drive with just about any op-amp.
Edit: crossed rayma's post, nice to see that we agree.
Yes, 1k could be a bit difficult for some circuits, but most should handle 2k.
Any higher than 2k, and you start losing too much level with the 10k pot load.
- Analogue Source
- Stereo To Mono
