RIAA preamps versus real loads
Old Today, 12:34 PM   #101
carlmart is offline carlmart  Brazil
Don't have a test record or plan to get one.
Old Today, 12:38 PM   #102
MarcelvdG is offline MarcelvdG  Netherlands
Then you have to resort to the method Hans proposed in post #95.
Old Today, 12:40 PM   #103
Now what about supplies for this RIAA preamp?
My inclination is toward using Jung/Didden supplies that I will assemble myself.
For a time I did consider 3X7 supplies with denoizators (hopefully everybody knows what I'm talking about) but I have read scarce feedbacks on how it affects the audio quality.
Other options seems to be LT3042/45 power supplies, but assembled ones come not cheap. And my experience with SMD parts is close to none.
What are your opinions on this matter?
Old Today, 12:41 PM   #104
Yes, I already got in contact with Bill and he suggested for me to send the photos.
Better yet would be to find the original Grado box.
Old Today, 12:46 PM   #105
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
I am a fan of Jan's silentswitcher, but aware I am into advanced **** polishing with that as Hans and Syn08 have proven.
Old Today, 02:11 PM   #106
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
If the current consumption is below say 20mA (you could always parallel the two halves in a dual to get 40mA) the LM4562 makes a superb linear reg. PSRR at LF >110 dB and its still 80 dB at 100 kHz and its very low noise (pV/rt Hz).
Old Today, 03:16 PM   #107
What linear regulator would be that? I would like to simulate it in LTSPice and compare it to the others.
Old Today, 03:27 PM   #108
As op-amps have a pretty good PSRR at low frequencies, plain old 78xx/79xx supplies should work fine - but using something fancier won't do any harm, of course.
Old Today, 03:47 PM   #109
My comparisons between 78XX/79XX and 3X7 in the '80s and later went very bad for the former, always.
  Reply to this post
RIAA preamps versus real loadsHide this!Advertise here!
Real RIAA preamps versus real loads carlmart Analogue Source 4 12th October 2020 04:14 AM
an observation about RIAA preamps bullpeters Analogue Source 16 12th September 2014 01:54 PM
Simulating real-world loads? Holgi Solid State 12 24th November 2013 01:38 PM
preamps, ss versus tubes philmagnotta Solid State 233 18th June 2010 11:07 PM
Simple RIAA phono preamps Optical Solid State 81 26th November 2002 10:27 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
