Tiny little phono preamp on the tonearm just behind the cartridge ?
Old 15th October 2020, 10:53 AM   #41
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
It's just a matter of effective arm mass plus cartridge mass vs. stylus compliance. Both need to be arranged so that the resonant frequency is about 6 to 8 Hz.
The tonearms by Dual that I've mentioned previously usually are already provided with a five wire cabling (red, green, white, blue as usual plus black for arm and shell ground). Hence modifications weren't needed with it.
Best regards!
"I spent a lot of money on booze, birds and fast cars. The rest I just squandered." (George Best)
Old 17th October 2020, 01:24 PM   #42
Hiten is offline Hiten  India
Hiten's Avatar
sorry for late reply.
ahh Ok I was under impression and thinking that preamp module would make things heavy and to reduce weight suggested the tube sections.
Regards.
Old 17th October 2020, 02:15 PM   #43
I think especially billshurv's idea in #5 isn't necessarily much heavier than an ordinary headshell. One should be careful with it though, as it requires a tonearm with adjustable base to get the VTA right. The cartridge mounting plane is beneath the arm's axis, but usually it is higher wrt. the axis.
Best regards!
Old 17th October 2020, 10:17 PM   #44
egellings is offline egellings  United States
Might the ceramic caps in the headshell-mounted preamps have an adverse effect on sound quality?
Old 17th October 2020, 10:23 PM   #45
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
only if you believe they do
Old 18th October 2020, 11:35 PM   #46
Mark Tillotson is offline Mark Tillotson
At low signal levels, less effect, but they are microphonic as well as distorting, so not an ideal choice.
You can just use PPS caps though. PP would be better but are not available surface-mount as polypropylene has a very low melting point. PPS is pretty close to PP in performance, handles high temperatures, and is nowadays commonly available.
As used here in my tone-arm RIAA preamp / rumble filter:
Phono plug for scale.
Old 18th October 2020, 11:49 PM   #47
EUVL is offline EUVL  Europe
Haven't we discussed this beforen?
Putting a super light phono amp inside the tonearm?
4-wires, BTW.
Patrick
xen-audio.com
  Reply to this post
Tiny little phono preamp on the tonearm just behind the cartridge ?Hide this!Advertise here!
New principle linear tonearm and phono cartridge (DIY) Tom Bloem Analogue Source 96 20th December 2016 10:17 AM
How to tune your cartridge-tonearm-cable-preamp to ge the best! murillollirum Analogue Source 15 23rd September 2015 01:52 AM
Phono Preamp for Creamic Cartridge kokuhorice Analog Line Level 6 17th August 2011 10:40 PM
Tonearm / cartridge. jonatan Analogue Source 4 19th July 2010 09:12 PM
Some Cartridge and tonearm input please mashaffer Analogue Source 19 10th June 2005 08:45 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
