Share your Ortofon Red experiences please
Old 23rd May 2020, 02:06 PM   #1
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Share your Ortofon Red experiences please
I ordered and received an Ortofon Red Verso today. Since it was the only Red version the shop I prefer had (and I needed instant gratification). I did however try to find out of that is the version I could fit to my RB250 arm. Since it looked do-able. I got the verso. Guess what? I won't fit the bolt is too short. No biggy since I can just unscrew the top plate and fit longer ones.
Here is my rant though. By using google I could not find a single sentence which arms the verso is suitable for. ( configuration for bottom headshells is the only explanation )
So now when someone googles at least they can find: "Do not order the Verso for your RB250 unless you want to diy". I ordered m2.5 length 6mm and 8mm now. Since the bolt that comes with it is 4mm.
Rant and info over. I'm curious about the experiences from other owners of the Ortofon Red.
http://basaudio.wordpress.com
Old 23rd May 2020, 02:34 PM   #2
mhenschel is online now mhenschel  Canada
Interesting.
A few months ago a friend bought a Quintet Blue and enthused. Not knowing anything about these I went to the Ortofon site and was struck by the prominent note with respect to Rega tonearms. I see the same note on the Red Verso page:
2M Red Verso
Oddly enough, there's no mention of the screw length problem.
And whilst in their FAQs Ortofon advise against pairing their "black" models with Nude Shibata diamonds with Rega arms (because the necessary precision for VTA adjustment cannot be made with spacers) they fail to mention this on the "black" model pages.
Old 23rd May 2020, 02:49 PM   #3
Hi mhenschel,
I did notice that text. And added a 4mm spacer...
Old 26th May 2020, 03:53 PM   #4
HarryY is offline HarryY  United States
HarryY's Avatar
I have the Blue and I'm happy with it.
The blue is the same cartridge as the red with a different needle
Old 26th May 2020, 04:01 PM   #5
schiirrn is offline schiirrn  Germany
The Red is my goto cartridge when affordable and simple are the main objectives. It sounds very alive, which I like. The last two I installed on a Tesla (after which the Regas are modeled) and a Sony direct drive table. On both installation was easy and straightforward.
Preferred BSC? Just using a wide enough baffle.
Old 26th May 2020, 05:52 PM   #6
AnthonyA is offline AnthonyA
I have om 10
Which is the same as ortofon red as far as I know internal is same. It's also said to be a moving iron design.
I have bunch of carts and om 10 is one of my favorite. If can get the sra right..quite sensitive to good sra settings (I struggled with it)
The character is is good seperation, wide and deep staging , natural and good amount of texture. Only thing I don't like it requires a fair bit of cleaning.. The stylus likes to attract dust
I might get a lp gear vivid line for the replacement stylus
Old 26th May 2020, 07:17 PM   #7
Nice to have an upgrade path!
Old 26th May 2020, 08:25 PM   #8
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
I had a Black and when installing it, one of the pins pulled out. End of cartridge. However, one of the guys here on diyaudio told me the black stylus (Shibata) worked with the Red so I ordered one and yep, it worked perfectly. So it seems the styli on these Ortofon carts are interchangeable.
BTW I emailed a Ortofon aNd explained what had happened and asked if they could sell me just the cart minus the needle since the needle was about €275 IIRC and they refused.
The reason the pin came out the rear of the car is that it is NOT KEYED INTO THE PLASTIC.
With the greatest respect, how dumb is that?
Old 26th May 2020, 08:50 PM   #9
@bonsai
Interesting. I wonder if that's true for the Quintet series too?
Part of the OP was the "brain fart" w.r.t. mounting screw length for Rega arms despite Ortofon making particular efforts in notes about those arms. And it turns out they had a "hidden" note about the unsuitability of Black level cartridges to Rega arms. I take it you aren't using a Rega arm.
How did the cartridge respond to fine tuning azimuth etc?
Old 26th May 2020, 09:10 PM   #10
hpro is offline hpro  Switzerland
Hi guys
I also use Ortofon.. Usually I use Turbo 3 MC on my Turntable.. which is an old Revox B795 Linear Tracking but I already broke two of them and over the time it's too expensive to brake the needle, as I had to throw away the complete head. Moving Coil is no way to change the needle.
So I ordered 2M Bronze. Good Sound wide and full of strength, but the Timbre of Super High were missing to some point *it's not a problem of the cartridge itself.. it's also my ears". The Stage of the music is good, but Ortofon has better for not too much money more. 2MBlack. I didn't ordered the Verso Version *Bronze* because I didn't see it.. So when the Cartridge came I had to modify to fix it to the Tangential Arm and holder..
Done it sounded very good.. Since the Head of Bronze and Black are the same I didn't need to modify the black one.. just exchanging the needle was enough.
The black is very good and comes very close to TD3 MC..but it don't surpass it even it's about 200Euro more expensive than the TD3.
I have good digital weight gauge where you can measure 1/1000 of a gramm.. mine adjusted 1.8Gramms. Otherwise the needle jumps tracks.
That's my five cents to this..
Share your Ortofon Red experiences pleaseHide this!Advertise here!
Ortofon OM/Super OM billshurv Analogue Source 14 11th January 2017 11:40 AM
Ortofon VMS20/30 davecooper Analogue Source 24 18th September 2013 08:36 AM
Ortofon FF 10 E Arckivio Analogue Source 3 30th May 2013 07:39 AM
Ortofon Tonearm nyatt Swap Meet 0 12th December 2005 01:13 PM
Ortofon SPU version ?? sippo Analogue Source 2 20th May 2005 07:00 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
