Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Community
RIAA Noise Calculator
Thread Tools
Old 20th March 2020, 04:24 PM   #1
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Default RIAA Noise Calculator
Here is a link to the RIAA noise calculator I mentioned a few months ago that I was working on. Its linked to in the 'broadcast blues' thread as well.
The spread sheet is derived from Stuart Yaniger's one with additional inputs to allow the real world noise for up to 5 opamps or discrete amplifiers to be compared.
So Just How Quiet is Your Phono Stage?
!ONLY ENTER DATA IN THE GREEN CELLS!
Bonsai X-Altra MC/MM preamp http://hifisonix.com/x-altra-phono-eq-preamp/ Ground Loops http://hifisonix.com/ground-loops/
Old 21st March 2020, 03:33 AM   #2
sgrossklass is offline sgrossklass  Germany
sgrossklass's Avatar
March 19, 2019?
The table heading "Signal to Noise Ratio with input SHORTED ref 1V and ref 0.25V" is in fact not accurate. You have no information for the RIAA network to go on. (Not even Rg, which would make for a decent approximation.) Besides, not sure what the point of this table is even supposed to be. Why 1 V and 0.25V? Why not 2.5 mV and 5 mV?
Formulas in cells V9 and Y9 are referring to J31 and P31, respectively - other cells in these columns are referring to J32 and P32 instead.
'Re(Z) (ohm)' (I31) is actually not 'Cartridge only impedance'.
'|Z| (ohm)' (I32) is not equal to 'Cart and load resistor paralleled impedance' (AE32).
Ultimately, what you want at the end of the day (IMHO) is the RMS sum of:
* opamp voltage noise
* thermal noise of Re{ Z_cart || Rin || -jX_Cin }
* i_n * Re{ Z_cart || Rin || -jX_Cin }
I've been thinking about how one might accommodate amplifiers with extra common-mode current noise from bias current cancellation. As mentioned in the 'broadcast RIAA blues" thread, these have substantially more input current noise when impedances are highly mismatched, as they happen to be in a typical phono MM application. For example, LT1115 i_n is given as 0.9 pA/√(Hz) with matched impedances, but when confronted with 10k vs. 0, this effectively rises to about 3 pA/√(Hz).
At present, my opamp noise calculator does not care one iota about any correlation between input noise currents. 10k + 0 gives the same results as 5k + 5k. Actually, they are literally summed internally, simplifying the calculations.
In a few hours of research of thinking, I've come to the conclusion that
1. one current noise source between inputs is functionally equivalent to two of identical value from each input to ground (this is because you can basically split every ideal current source and put the midpoint at arbitrary potential, and no-one will be the wiser; now it's no longer quite so equivalent if we are looking at the topic of correlation - but this may prove useful when it comes to splitting between differential mode and common mode contributions)
2. my Ib to i_n conversion contained a double fault - I was using a factor of 2 because I erroneously thought this was needed to accommodate the Ib of both inputs; in fact, it is the input current noise of bipolar transistors that is the sum of two terms, one the shot noise of Ib and the other being the shot noise of Ic divided by beta - note that internal current sources and mirrors may add to the Ic noise term! Thankfully, if the opamp is full of noiseless "stuff", this reduces to the shot noise of Ib + Ic/beta = 2 * Ib. So still good for a lower boundary. Phew.
If (2) is true, I may have to distinguish between BJT and FET inputs. So far, I have not seen any indications of significantly more than input gate current being involved. Well, JFETs still have funny complex terms (being capacitive devices) that can interact with complex source impedances. Which is why it is said that they like inductive source Z.
Looks like I will very much have to look into the noise of current sources and mirrors. Imagine your tail current source contributes a certain degree of noise of its own - it will be mirrored with the current across the input pair and appear as correlated Ic noise, on top of the junction-related shot noise already present. That might explain why low-noise designs often rely on plain ol' resistors only (pure conductors have no shot noise).
Old 21st March 2020, 09:19 AM   #3
Bonsai's Avatar
The cells that calculate the S/N ratio at 0.25 and 1V are there to give an indication of the noise levels at typical preamp outputs - 0.25V for legacy preamps and 1V for 1dBV. This basically emulates what you would get feeding the preamp into a sound card. The signal to noise ratio given at the top right hand box (by the red box) is calculated with reference to the specified cartridge input voltage. This is what I would use for everyday comparisons.
You don’t need to know the feedback network impedance to get an accurate handle on the total input refereed noise. The cartridge noise and the lower feedback resistor noise - which is a fraction of the feedback network impedance- dominates the noise even at 20 kHz (RMS sum). But, I take your point and will add a cell for putting Rg in - this is typically 50 to 1k (which is on the high side - normally 100 to 220 ohms for noise and network value convenience IMV).
Re mis matched current noise opamps - it’s best just to look to better devices - but it would make an interesting exercise. You will note from the spread sheet that the NE5534A remains remarkably good despite it being 40 years old!
I will take a look at your other points a bit later today - thanks for the feedback.
Old 21st March 2020, 11:48 PM   #4
Basically a good idea, but AFAICT the calculation is normalized to a gain of unity at 1 kHz, vs. the typical 34-40 dB of MM RIAA stages (another piece of information you do not have but probably should). Effectively you are dividing 1 V or 0.25 V by effective input noise with cartridge attached, which (a) makes precious little sense and (b) has nothing to do with "input shorted" at all.
Mind you, I had to fix some nonsense in my opamp noise calculator today, too. Yesterday I boldly wrote
...but in fact that is not true. Input Ib of both transistors is in general uncorrelated, so you also need two uncorrelated noise sources. If you had just one shared between inputs, that would clearly be correlated.
The latter was what my calculator was doing. So it would estimate the noise of unbalanced impedance correctly but be 3 dB too conservative in the case of matched impedances (since i_n * R + 0 = sqrt(2) * RMS(i_n * R/2, i_n * R/2)). I was playing around in LTspice today, which confirmed this. Been like that for years, nobody ever bothered to complain.
Still not actually sure how to best obtain two orthogonal terms to accommodate this correlated noise source business. Can I just add a i_n,cor * |Delta R| term? But even if so, how would one obtain i_n,cor from datasheet graphs? I would have to "un-RMS" the two i_n terms adding up in the unbalanced case, subtracting the uncorrelated noise term (something for which I fortunately wrote a calculator recently). This is because the cases "Rs + Rs matched" and "Rs + 0" are not actually orthogonal - you'd need "Rs + (-Rs)" instead. Now negative impedance is a mess so the two existing cases are going to be as orthogonal as it gets.
Old 22nd March 2020, 09:04 AM   #5
Bonsai's Avatar
I would not sweat about noise arising in opamps that use input bias current cancelling - very few if any of the bipolar input opamps best the 5534A on noise - LM4562, AD797, LME49710, LT1115 all fall down on MM because of their noise current.
If you want a bit lower noise, my recommendation for MM is to go for the OPA1641 (€3). The AD745 is also very good (but expensive - about €10 each last time I looked). For the ultimate in noise, you have to go for LSK389 or better still BF862 if you can find any.
Re the gain point - you don’t need to know gain to calculate noise - that’s the whole idea of using input referred noise voltage. Once you have that and the signal input level, you can calculate the S/N directly.
Old 22nd March 2020, 10:06 PM   #6
Bonsai's Avatar
A straight RMS sum of Rg noise gives between 0.2 dB and 0.4 dB increase in noise for Rg = 220 Ohm.
But, this was just from adding the noise - not equalizing it which will result in a lower overall noise impact - that will have to wait for next week - busy doing PCB spin 2 of a new phono EQ.
Old 23rd March 2020, 01:39 PM   #7
Mark Tillotson is offline Mark Tillotson
I find the table almost impenetrable compared to a noise/frequency graph - surely a spreadsheet isn't the best tool for presenting the results accessibly?
Old 23rd March 2020, 02:12 PM   #8
Bonsai's Avatar
Good point Mark. I'm adding some graphs that will show the noise per band graphically per opamp. I'm pretty busy at the minute but hopefully will get something out in a week or two.
Old 23rd March 2020, 11:47 PM   #9
Ah excellent.
Old 24th March 2020, 03:22 AM   #10
rsavas is offline rsavas  Canada
Still would like to see you compare the NE5534A vs the new OPA1656, which imo is a pretty good deal vs some of those much more expensive ADI jfet types such as ADA4625-1
RIAA Noise CalculatorHide this!Advertise here!
BC550 BC560 Very low noise RIAA lineup Analogue Source 459 14th February 2021 06:45 PM
Phono cartridge noise calculator SY Analogue Source 27 13th June 2012 04:14 AM
Riaa component calculator hacknet Analogue Source 7 12th November 2011 09:58 PM
Noise on the RIAA phono preAmp diarav Chip Amps 3 23rd March 2007 05:27 AM
Who's measured the noise on their RIAA preamp? CeramicMan Analogue Source 20 19th February 2004 06:35 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
