Revox G36 motor caps advice please
Old 20th March 2020, 06:43 AM   #1
jascha is offline jascha
Smile Revox G36 motor caps advice please
Hello everyone,
Iím in the middle of restoring my G36 and whilst I have the front separate from the back to carry out maintenance on the motors (clean old grease and replace bearings etc) and replace caps on the push button module with x2 type, I would like to take the opportunity to replace the motor run caps.
Taking apart a G36 is very time consuming so itís worth doing all I can to service it.
Could I get advice please if these Kemet caps in the link below would work well on the G36? These are rated at 3.5uf 5%. I would welcome advice please and if these wonít do the job where can I get a set for my machine please? As Iím in the UK Iím trying to find stock in this country right now.
Also could I find out what type of diodes are used on the push button modules? Are they standard silicon diodes ? Would something like a 1N4001 work as a substitute?
Here is the link..
404 - File or directory not found.
Many thanks
J
Old 20th March 2020, 08:08 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Do you mean C70/71&72?
If so the value is of little importance and are there to give phase shift for the motor determining the direction of rotation. If they are not short circuit, I would leave them alone.
Diodes D1/2/3&4? 1n4003 would suit well if you have short circuit diodes, which I doubt.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 20th March 2020, 08:44 AM   #3
Thanks for reply. They are fine so far as I know but was questioning if they were worth replacing once I have the machine stripped.
One other question.... I want to clean the old grease from the capstan motors and relubricate it however I canít find the right tool to take off the 4 studs. What can one use or any tips of what the tool should look like please? Itís not easy to grip the nuts to undo them.
J
File Type: jpg EFEB5AE5-A170-4540-9495-B47B83430FB6.jpg (615.4 KB, 84 views)
Old 20th March 2020, 10:38 AM   #4
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
These appear to be standard hexagonals. So I'd try the suitable socket from my set of spanners.
Best regards!
"I spent a lot of money on booze, birds and fast cars. The rest I just squandered." (George Best)
Old 20th March 2020, 11:56 AM   #5
ralphfcooke is offline ralphfcooke  United Kingdom
You'll probably need a tube spanner, most sockets aren't deep enough.
A possibility is a ring spanner, but it would have to be very thin.
Old 20th March 2020, 02:23 PM   #6
blinker is offline blinker  United States
To remove those bolts, I modified an 8mm deep socket. The socket is too thick to fit in the recess, so you need to thin the wall. Easy if you have a lathe. If not, spin it with a drill and file down the end of the socket to make it thin enough to fit.
Be careful when you rebuild the motor and don't overtighten those bolts. They snap very easily. I had to fasion a new one from threaded rod and a couple nuts.
Old 22nd March 2020, 05:26 AM   #7
Thanks for the tips. I did think of thinning down a hex drive however I did not try on a lathe as I would have thought that itís hardened steel and would be a tough job. I was lucky that I managed to ease 2 of them with flat nose pliers at the end... originally I was attempting to carefully undo them by holding them with a grip vice from the thread by applying gentle pressure but was afraid that they would snap.
After I took then off I could see that one could replicate it then with a threaded rod and a nut! I just canít understand why itís been manufactured in such a way to complicate matter when it comes to servicing them!
Cheers
Old 23rd March 2020, 01:48 PM   #8
Mark Tillotson is offline Mark Tillotson
Run caps, unless they've failed, should be fine, they are film caps. The value _is_ important,
as the two windings need be matched for current and in the right phase relationship for good
efficiency and low vibration. Too much current due to over-valued run cap can overheat a winding and burn out the motor.
Old 23rd March 2020, 08:04 PM   #9
Thanks for the technical useful info. I have fitted exact replacements as even though they might last for a while, the originals are bound to fail and it’s a pain to get to them and do a proper job. I replaced them with just modern equivalents and they work just fine. I feel relieved that I did this job so I don’t have to worry about them for some time.
Cheers
Revox G36 motor caps advice pleaseHide this!Advertise here!
Revox B225 Spindle motor bearing Depaj Parts 20 16th August 2018 11:54 AM
WTB: Revox A77 high speed (7.5/15ips) capstan motor ridikas Parts 0 16th December 2016 04:13 PM
Wanted - Tray motor for Revox B225/Studer A725 khjen Swap Meet 1 25th July 2016 08:51 PM
Replacing a Brushed Motor with a Brushless Motor - Advice needed. Salar Digital Source 14 17th August 2015 10:40 PM
Revox B710 cassette deck spool motor poblem Willi Studer Analogue Source 2 7th February 2008 09:48 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
