Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Thread Tools |
#31 |
Hello after photoelectric servo modification on my Rabco SL8E with led (same nero52) I have notice led turn on & off very few seconds, it’s correct.? Or led continuously turned on? Thanks Rajkumar
DIY Horn, Rethm Saadhana V2, Gaanam Amp, Dared 845 KR Tubes, Dared 300B, Dared DL2000, CEC TL1 CD Transport, Meridian G08, Bryston BDP-1, DAC Antelope Zadiac Gold, Cable Kimber Monocle XL, AQ SKY, Norduct. Analog: Kenwood L-07D, R2R Pioneer RT-909 |
#32 |
The LED circuit itself is probably working correctly. The ideal is for the motor to operate continuously, and speed up or slow down as the groove pitch varies. You can verify this most easily by monitoring motor voltage directly with an analog voltmeter. With a theoretically constant groove pitch, the motor voltage will also be constant. Groove pitch in the real world is not constant and records are also off-center to some extent, so motor voltage isn't constant but varies up and down with each revolution. LED's like to be either on or off. My guess is that the LED circuit is biased somewhere in the middle of the motor's actual operating voltage range and is turning on and off as the motor swings within that zone. The LED turn-on point could be manipulated by selecting the gain of the added transistor and the value of the added 4K7 resistor.
I deliberately did not include an LED indicator on my arm partly out of laziness but more out of the philosophy that, if I can't hear the effects of the servo in action, I don't want any visual cues that it's operating. I leave my test equipment connected for as long as I need to see what the servo is doing while setting it up but once that's done I prefer to fly/listen 'blindfolded'. Ray K
If more is better, then too much is just right. |
#33 |
Rayk absolutely you correct, I have check many LP's many of then off center this is the reason led light (motor) turn on/off, one of the my LP I found correct center than led turn on continuously. Now I have cleared my doubt. I have installed 2 led red & green. Green for carriage and red for lifting. Everything working perfectly. I have post some pictures. Tks lot Rajkumar.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Infinity Irs servo control | rvito | Multi-Way | 0 | 11th May 2017 03:16 PM |
Simple Servo Control | KatieandDad | Everything Else | 0 | 2nd January 2014 02:19 PM |
DIY Servo Sub- need help with control circuit | flyingtele | Subwoofers | 1 | 28th January 2013 08:57 PM |
Does anybody know how to use the MCU to control the CD servo? | zhangzq71 | Digital Source | 0 | 19th December 2008 04:52 AM |
Photoelectric valves? | bigwill | Tubes / Valves | 7 | 11th May 2005 04:27 PM |
New To Site? | Need Help? |
