Rabco SL8E Photoelectric Servo Control Retrofit
Thread Tools
Old 22nd October 2020, 02:24 PM   #21
nero52 is offline nero52
Hi diyrayk
I have just modified my very old Rabco SL8 with your help on this site. Everything works fine with the optical reading, it's absolutely great!
Thank you very much for posting this step by step manual.
I even spent a green led for transportmotor, so i can see when he's in action.
Greetings from Switzerland, nero52
Old 22nd October 2020, 02:31 PM   #22
Default Modified Rabco SL8
Two images, work is done!
Old 26th October 2020, 08:48 PM   #23
diyrayk is offline diyrayk  United States
diyrayk's Avatar
Glad to see another happy user of this mod. Do you have any more photos of your construction details? I like to think that the green led indicator was necessary because the motor was now running too quiet to hear, or is that vanity on my part?
Ray K
If more is better, then too much is just right.
Old 26th October 2020, 09:32 PM   #24
Hi diyrayk
there are only two more photos. The green led indicator is just for my fun, to see that the motor is working. i have never heard the motor, but i spent hours in front of my rabco - hoping it works.
i couldn't adjust the two contactwires anymore and instead of them i took two small pieces of guitar strings. that worked for two month...
now i'm very happy after the photosensor upgrade, but i spent some hours to make it. every minute is worth it!!!
Old 2nd December 2020, 04:02 PM   #25
Rajkumar_ is offline Rajkumar_  India
Hi Ray thank you for your great posting, I had modified my Rabco SL8E working very good. Motor run very quietly, visually not possible see the carriage moment. I am very happy, this arm will work another 50 years trouble free. I would like add led for carriage motor moment like Nero52. I had try to add led before R1 resistor (Q1 collector), working but I feel motor get too slow! Pls advice where I can connect led. Tks Rajkumar
DIY Horn, Rethm Saadhana V2, Gaanam Amp, Dared 845 KR Tubes, Dared 300B, Dared DL2000, CEC TL1 CD Transport, Meridian G08, Bryston BDP-1, DAC Antelope Zadiac Gold, Cable Kimber Monocle XL, AQ SKY, Norduct. Analog: Kenwood L-07D, R2R Pioneer RT-909
Old 2nd December 2020, 05:10 PM   #26
Hi Rajkumar_
see schematic
Old 2nd December 2020, 08:54 PM   #27
Rajkumar_
i took the 5V (Power Supply) direct from my Thorens TD 125 with a step down Module. Make sure, that the Voltage is correct after modifying with the Led, otherwise the transportmotor is too slow.
I mounted all the electronic parts onto a little print and put it inside the battery housing.
Best regards
Richi, nero52
Old 3rd December 2020, 02:11 AM   #28
Hi nero52, thanks for your answer, so I need 1k & 4.7k what is number of transistor T1. Rajkumar
Old 3rd December 2020, 03:50 AM   #29
I plan to use BC546, 547, 550 or 2N3904/2N222a which one available in market. Tks
Old 3rd December 2020, 09:14 AM   #30
Hi Rajkumar_
you can use any of them - no problem. Voltage is 5V and the current less than 5mA. I used a BC 107 (had this in stock).
Best regards
Richi
Rabco SL8E Photoelectric Servo Control RetrofitHide this!Advertise here!
Thread Tools
Infinity Irs servo control rvito Multi-Way 0 11th May 2017 03:16 PM
Simple Servo Control KatieandDad Everything Else 0 2nd January 2014 02:19 PM
DIY Servo Sub- need help with control circuit flyingtele Subwoofers 1 28th January 2013 08:57 PM
Does anybody know how to use the MCU to control the CD servo? zhangzq71 Digital Source 0 19th December 2008 04:52 AM
Photoelectric valves? bigwill Tubes / Valves 7 11th May 2005 04:27 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
