DIY turntable build
DIY turntable build
Old 24th August 2019, 02:46 PM   #1
vdub8 is offline vdub8  United Kingdom
Default DIY turntable build
I’m looking for second hand parts as to what makes and models
Bearing as to which bearing or what’s available out there
something a bit better than run of the mill
A stand alone motor and pulley
A platter to be run on the outside
I hope to make my own
Motor housing again I’m new to this but switch gear or transformer required
Bearing housing
Arm later on once the turntable is made
Arm housing
Any help or shove in the right direction would be appreciated
Cheers Jim
Last edited by vdub8; 24th August 2019 at 04:24 PM. Reason: I’m looking for parts but I don’t know enough to who what or where has them
Old 24th August 2019, 03:41 PM   #2
Duke58 is offline Duke58  United States
Maybe try the Swap Meet part of the forum?
Old 24th August 2019, 03:47 PM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
DIY turntable build
just buy an old turntable off eBay and strip for parts
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 24th August 2019, 03:49 PM   #4
BINGO!!!
Old 24th August 2019, 04:20 PM   #5
My thoughts were can’t afford to buy complete turntable all at 1 time but I could buy parts when they appear
Old 24th August 2019, 05:18 PM   #6
Bigun's Avatar
DIY turntable build
To be honest I think you’re kidding yourself, there are some used turn tables out there for very little money but what it will cost you for the parts, especially if you pay postage and then all the time it is going to take you to build it then all the frustration when it doesn’t work very well - all that time could be way better spent doing something else - take the time and do a paper around it and earn the money, the second hand turn table doesn’t have to cost a lot of money to get you going
Old 24th August 2019, 05:42 PM   #7
Galu is online now Galu  Scotland
Originally Posted by vdub8 View Post
My thoughts were canít afford to buy complete turntable all at 1 time but I could buy parts when they appear
The Pro-Ject turntable parts from Henley Audio are new - not second hand - and not necessarily inexpensive.
However, they do fit your requirement in that you can buy them one at a time.
Pro-Ject Turntable Spare Parts
Old 24th August 2019, 07:45 PM   #8
hottattoo is offline hottattoo  United States
Rega has turntable parts along with many after marker parts makers for Rega. You need to give an approximate budget and the skill level you have . A turntable is a simple device but getting everything right, properly fitted is another story. Good luck with your project.
Old 24th August 2019, 08:05 PM   #9
6L6 is offline 6L6  United States
6L6's Avatar
DIY turntable build
Boot sale? Local swap meet? There's a lot of turntables in the world.
Old 24th August 2019, 08:24 PM   #10
AVWERK is offline AVWERK  United States
AVWERK's Avatar
VPI parts come up quite often and are solidly built.
David
DIY turntable buildHide this!Advertise here!
Turntable plinth build crazy bill Analogue Source 0 17th September 2017 06:23 PM
Waiting to build a turntable, but need some help... Kentaro Analogue Source 21 15th January 2017 12:03 PM
Help me build a DIY Plinth turntable blue934 Analogue Source 6 15th November 2015 02:53 AM
turntable design and build ijpdesign Analogue Source 17 17th October 2012 11:25 PM
The build starts. (DIY Turntable) kilowattski Analogue Source 19 20th May 2008 12:31 PM
Copyright ©1999-2019 diyAudio
