Rega T/T HELP
Rega T/T HELP
Old 17th July 2019, 01:41 AM   #1
gigigirl is offline gigigirl
Default Rega T/T HELP
Hi, I picked up a Rega T/T at a local garage sale.
Got it home & when stared it up & the platter ran backwards at 33 RMP. Switched it to 45 RPM pulley & it ran correct. The belt was very sloppy, so I thought it would need a new belt, which I purchased from F/Bay.
Belts arrive today, seller supplied two. Fitted to T/T & exactly the same result. Now just to see I fitted the two belts to both pulley diameters, and T/T ran correct rotation.
I have also applied an ''O'' ring to the back of the motor to tighten up the pulley/belt interface further, but that made no difference.
Any suggestions
Cheers
Old 17th July 2019, 02:01 AM   #2
rayma is online now rayma  United States
Could be a bad capacitor, check the connections and then replace the cap.
Clean all the drive surfaces that the belt touches with alcohol for better friction.
Otherwise, it may be the motor.
Old 17th July 2019, 07:02 AM   #3
K.A.B is offline K.A.B  Sweden
K.A.B's Avatar
I had same problem with a rega i bought at a fleemarket after little tinkering i change the capacitor and resoldering the pcb it worked, try it first.
Anders
Old 18th July 2019, 05:54 PM   #4
Mark Tillotson is offline Mark Tillotson
This will be the motor run capacitor? Yes if that's failing the motor will run either way as the auxiliary winding isn't operating.
Old 18th July 2019, 10:07 PM   #5
Thanks' guys, will try picking a new one up at the weekend from JCar.
Cheers
Old 31st July 2019, 04:36 AM   #6
Hi Guy's Thanks for the advise on the new capacitor, T/T now working A1.
Cheers
Rega T/T HELPHide this!Advertise here!
Rega Ela MK 1 analogKidA Multi-Way 0 22nd December 2018 02:15 AM
DIY Rega TT PSU vinylpaul Analogue Source 1 7th January 2015 09:10 PM
Rega Dac usp1 Swap Meet 0 2nd February 2014 07:43 PM
Rega P25 vs P5 gbale Analogue Source 3 23rd March 2010 07:19 PM
rega p2 hum mpmarino Analogue Source 7 20th August 2006 02:38 AM
Copyright ©1999-2019 diyAudio
