Richard Lee's Ultra low Noise MC Head Amp
Old 20th July 2019, 11:53 AM   #731
Hans Polak is offline Hans Polak  Netherlands
Digging a bit deeper into the LF bump problem, I tried to find the pro's and con's of various measures.
Starting with the damping as suggested by Bonsai:
It has no impact on noise and some minor effect on THD and Gain, nothing to worry about,
Damping is indeed applied, but for a Duraglit amp that has just enough dynamic range without damping, it seems rather unacceptable that DR may be reduced up to 10dB depending on the setting.
So when using this damping by placing resistors in the output line, this has to be done with great care.
Another way of getting rid of the LF bump is to reduce the output cap from 220uF to a much lower value like somewhere between 10uF and 22uF.
No reduction in DR will happen and no tuning will have to be done when using large caps for the base voltages of both transistors.
In the Image below, the left column applies when using a collector current of 2.8 mA, the right column for 6mA to reduce noise if needed.
Simulation is done for a 5R (in green) and a 10R (in bue) Cart, having an output of 0.5mV@5cm/sec@1kHz, thus needing a Headamp with a gain of 10.
The three rows are resp. for 1) "no damping+220uF", 2) "220R damping+220uF" and 3) "no damping and 10uF".
For each individual situation, the effect of using a 0.5mF or a 5mF Cap is shown.
The effect of a larger Cap is mainly shifting the Bump to the "left", as can be well seen in the various plots.
I did the same simulations for a 2R and a 5R 0.25mV Cart, needing a gain of 20, and for a 1R and 2R 0.1mV Cart needing a gain of 50.
Results were quite comparable with the above.
So to conclude it can be destilated from the findings, that the larger Rs, the lesser the Bump problem, but I would strongly advise to always substantially reduce the two 220uF output Caps.
Hans
Old 20th July 2019, 06:26 PM   #732
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
What load resistor have you used on the output Hans? 100 Ohms?
Old 20th July 2019, 09:27 PM   #733
I have set the gain to exactly 20dB as needed for a 0.5 mV Cart, see text and images.
So for the four variations of Rs and collector current I have used 4 different load resistors to get exactly this 20dB gain, resp. 99, 162, 73 and 127 Ohm.
Hans
Old 21st July 2019, 01:21 AM   #734
gerhard is offline gerhard  Germany
gerhard's Avatar
Just stumbled across some Zetex/Diode, Inc transistors with healthy hfe.
BF=1100. There are more.
.MODEL ZXTN07012EFF NPN IS=1.7p NF=1 BF=1100 IKF=5 VAF=25 ISE=3E-13 NE=1.43 NR=1 BR=470 IKR=1 VAR=6.5 ISC=1.2p NC=1.5 RB=0.1 RE=0.03 RC=0.0097 RCO=0.2 GAMMA=10E-10 CJC=106p MJC=0.33 VJC=0.55 CJE=285p MJE=0.41 VJE=0.80 TF=0.4n TR=1.3n XTB=1.4 TRC1=0.003 TRB1=0.003 TRE1=0.003 QUASIMOD=1 Vceo=12 Icrating=4.5 mfg=Zetex
I was really looking for some DPAK to relief op amps of unnecessary heat (high VCC)
"That's right!" shouted Vroomfondel, "we demand rigidly defined areas of doubt and uncertainty!" "We don't demand solid facts! What we demand is a total absence of solid facts. I demand that I may or may not be Vroomfondel!"
Old 21st July 2019, 07:25 AM   #735
And the only supplier is Aliexpress ??
Old 21st July 2019, 08:41 AM   #736
gerhard's Avatar
< ZXTN07012EFFTA Diodes Incorporated | Diskrete Halbleiterprodukte | DigiKey >
Probably Mouser, too.
:-) Gerhard
Old 21st July 2019, 11:39 AM   #737
Interesting transistor with a PNP complement although again with an unrealistic Rb = 0R1.
Once Bill will be ready to send me his “Wayne” design, I could compare these trannies with the ZTX pair.
Hans
Old 21st July 2019, 01:07 PM   #738
This is a similar simulation as #731, but now for 0.1mV output 1R and 2R Caps, the Headamp thus needing a gain of 50.
Because these Carts demand a very low amp noise, I have simulated this time for collector currents of 6mA and 12mA.
The image below is just for the version with 10uF output caps and no damping, just like the lower version of the three in #731.
Again, using 5mF instead of 470uF base Caps in combination with 10uF output Caps, gives a perfect FR.
Hans
P.S. Correction: In the right plot is written Ic 6mA, this should be 12mA.
The left one is correct with 6mA.
Old 21st July 2019, 02:23 PM   #739
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Interesting high beta is usually a counter indicator for low rbb but this device also has very low Vcesat.
The 60C/W for SOT23 is interesting also since the pads look like standard size, seems to almost defy physics. Notes say big 2oz copper land needed but I'm used to big metal area on back of package for that.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 21st July 2019, 03:55 PM   #740
Bonsai's Avatar
Hans, on the Hawking, if you run your sims but look at the collector voltage of the transistors before the DC blocking caps (with or without dampers) what are you getting? This is with the 10uF capacitors
Richard Lee's Ultra low Noise MC Head AmpHide this!Advertise here!
ultra low noise regulators wtnsmk Power Supplies 26 2nd May 2019 03:12 PM
ultra low noise power supply and low noise amplifier ambrosia168 Power Supplies 8 13th October 2017 02:43 PM
Matching a 1970's receiver with these Richard Allan Loudspeakers? (Richard Allen) gearu Full Range 9 23rd September 2014 03:36 AM
Ultra Low Noise - Ultra Low Impedance - Ultra big Problems! Stefan0815 Analog Line Level 2 14th January 2014 06:01 AM
Ultra low noise filters tiroth Solid State 14 21st May 2002 10:19 PM
Copyright ©1999-2019 diyAudio
