Richard Lee's Ultra low Noise MC Head Amp
Old 19th June 2019, 03:32 PM   #31
syn08 is offline syn08  Canada
syn08's Avatar
Originally Posted by scott wurcer View Post
I guess there could be an issue with one size fits all, but I always try to set the gain for the cart in use.
That's probably part of the disagreement. DIY, no problem tailoring for your very own cartridge. A product, not so much, at least without a very expensive solution (recall JC gain wire wound gain pot). Providing a large overload margin is definitely cheaper.
Old 19th June 2019, 03:42 PM   #32
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
This IS a DIY forum after all. Doing things that could never be commerical products is where the fun is for me. A couple of transistors at the turnable phantom powered in a focusrite Scarlett is a potentially neat way of side stepping a lot of problems that analog front ends can have. A lot of people do rip vinyl. In fact some buy an LP and only play it once.
All good fun, and no bybees were hurt in the process
Old 19th June 2019, 03:45 PM   #33
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
billshurv:
what a great "coke-spitter" that was.
i'm still wiping my keyboard
mlloyd1
Old 19th June 2019, 04:10 PM   #34
syn08's Avatar
Of course, I was only trying to figure out where Tom Holman's opinion was originating from. TH didn't strike me as a DIYer .
Old 19th June 2019, 04:41 PM   #35
billshurv's Avatar
Ah no, I get you now
Old 19th June 2019, 05:00 PM   #36
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
No, but I wish he normalized all his data to one standard. Taking his last (worst case) graph I get 120mV for my 4mV cart, which is actually no problem except at the low end (maybe).
I wish there were more discussions of gain structure and overload margin, folks still complain when they use a miniDSP in front of their 106dB sensitivity speakers and find it noisy. They are running everything throwing away bits to get the output level low.
There is also the issue of overload at the input vs the output. I still don't see the point in specifying a line stage at 10V rms out when any normal 100 or so Watt PA would be hard railed at 3-4V.
Another thing about Mr. THX he talks about intermod with warp and LP eccentricity but this is not a pre-amp issue except in the extreme. The damage is done by the tracking angles and effective velocities changing, no amount of low pass filtering can fix that.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 19th June 2019, 05:10 PM   #37
syn08's Avatar
Yeah, there is though a good reason for that... traditionally, power amplifiers have clipping protections/flashing indicators/etc... Preamplifiers, not so much. It's probably a good idea to have a "single point of clipping", once again, from a consumer perspective. Of course, this is no good reson to feed a preamp at +/-24V and to make it almost rail-to-rail output (like, ahem, the Blowhard preamp).
Old 19th June 2019, 05:59 PM   #38
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
10V RMS Line stage OL is specmanship IMO. 2V RMS out will cover just about anything on the planet. But I think if you offered a product that overloaded at 2 or 3V out, you would get flak for it. Some things are best just left where they are. That said, the distortion sweet spot on a lot of gear is the 2-3V output level - just look at the AP plots on Stereophile of the more sensible stuff.
With overload and the phono EQ, you have the volume control normally between the EQ OP and the power amp or line stage preamp so having good OL on the EQ amp allows you to essentially adjust the signal chain gain at a convenient place to fit the program material dynamics.
Even for DIY preamps, I'd still design the phono stage for good OL.
(separately, I've just been loaned a Hanna ML moving coil cart - absolutely superb and a big step up from the Ortofon Red I've been using)
Old 19th June 2019, 06:03 PM   #39
jackinnj is online now jackinnj  United States
jackinnj's Avatar
Originally Posted by Bonsai View Post
Cables are also very microphonic - I suspect better quality noes with decent insulators are better in this regard. If you move them around they squeak and make all sorts of popping sounds at these amplification levels.
The physical movement of two dissimilar insulators causing charge to move. Tribolectric effect.
Testing for it by the folks at Molex:
Triboelectric Noise in Medical Cables and Wires - The Connector: By Molex
Old 19th June 2019, 06:10 PM   #40
syn08's Avatar
Bohoho, waa, waa, sob, sob, nobody is in a rush to loan me such expensive stuff . That must be one great cartridge.
Richard Lee's Ultra low Noise MC Head AmpHide this!Advertise here!
ultra low noise regulators wtnsmk Power Supplies 26 2nd May 2019 03:12 PM
ultra low noise power supply and low noise amplifier ambrosia168 Power Supplies 8 13th October 2017 02:43 PM
Matching a 1970's receiver with these Richard Allan Loudspeakers? (Richard Allen) gearu Full Range 9 23rd September 2014 03:36 AM
Ultra Low Noise - Ultra Low Impedance - Ultra big Problems! Stefan0815 Analog Line Level 2 14th January 2014 06:01 AM
Ultra low noise filters tiroth Solid State 14 21st May 2002 10:19 PM
Copyright ©1999-2019 diyAudio
