DIY Turtable Hum/Buzz issue
Old 10th June 2019, 02:23 PM   #21
Galu is online now Galu  Scotland
That's a fine piece of work! Your talent obviously lies on the mechanical side, and when you get the wiring sorted out you will have a pretty unique turntable.
Old 10th June 2019, 02:24 PM   #22
floxia is offline floxia  Australia
It's going to happen only thanks to you guys!
Old 10th June 2019, 03:45 PM   #23
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
looks good.
Old 10th June 2019, 03:50 PM   #24
Originally Posted by Koifarm View Post
looks good.
hopefully it will stop to sound like I hooked up wires to the power line and will start to play some nice music too!
Old 11th June 2019, 09:51 PM   #25
gigigirl is offline gigigirl
Default MM cartridges are known to be problematic for humming
MM cartridges are known to be problematic for humming,
Read the following link from SoundSmith.
Hum and or Noise Problems? | Soundsmith
Cheers
Old 17th June 2019, 11:46 PM   #26
6L6 is offline 6L6  United States
6L6's Avatar
That is an outstanding look table! Bravo!!
Old 21st June 2019, 06:30 AM   #27
nikosokey is offline nikosokey  Greece
nikosokey's Avatar
"""" Lock the arm down into position and turn up the volume till you hear some hum. Slowly bring you hand near the tone arm. If the hum increases, lack of shielded wires inside the arm, OR a non-metal arm may be the cause. If it is a metal tone arm, and you touch it, WITHOUT touching anything else with either hand, and the hum increases, the metal TONE arm is likely not grounded, and needs to be. It needs a wire from its metal base that runs to the preamp ground, and connects there along with the tone arm wiring ground wire."""
From table above my Thorens td 280 acting with same story , as you see the cables are twisted ,when i pull out the TT from my phone stage this little little noise it's gone .
when I close my finger on the head then the noise grows.
The signal after the phone stage amplified by 6V6 Salas as preamp.
It seems there is an extra cable inside the TT as Gnd this following the 4 twisted signal cables inside the tone arm.
File Type: jpg 716409d1542614857-phonoclone-vsps-pcb-help-desk-img_20181118_124856-jpg.jpg (394.0 KB, 50 views)
Titan 2000 ,Cressendo Millenium 2000, P3A ,VSSA ΤΟ3 ,B1 Buffer ,Golmund Mimesis 9.2 Clone ,Preamplifier Dispre 2 - JFET, DCB1 SALAS, D-Reflector, BibFet, Buffalo II,ES9018K2M, Arduino LDR Volume, AK4490 Discrete Mirand Audio,SSHV2, 6V6 Salas Preamp.
Old 7th August 2019, 03:29 PM   #28
UPDATE:
Sorry to everyone that contributed but I've slacked around with the project I've just gone back to it few days ago, after changing all the wiring as previously discussed now the turntable is wired as following:
- Cartridge to tonearm base -> twisted wires with gold plated connectors to the cartridge and female RCAs
- Tonearm base to preamp input -> 0.4m double shielded RCA cable
- Tonearm output to ampli -> 0.5m double shielded RCA cable
Conclusion: the buzzing decreased slightly but was sill there, pretty much no difference, so I scratched my head and out of ideas I hooked up a meter of single core copper wire to the preamp chassis ground screw and I chucked it inside the earth slot in the power outlet and boom that brought the buzzing down by quite a fair bit, now the buzzing starts to come up from let's say 75% of the volume.
I consider myself pretty happy with the results I've obtained and I can live with it, but I feel there is a bit more that I could do to improve it, if it can help when I touch the metal part of the cartridge the buzzing increases as well as if I touch it with a paper clip.
Thoughts? Bad Cartridge not helping the cause?
Sorry I haven't been in the forum for sometime and I missed your post, I want to thank you for your contribution, I didn't need to turn the volume up to hear the buzz trust me it felt like i hooked up my speakers to the power line hahaha
Jokes apart I'm not sure if you followed all the topic but there is a part where I explain that even if I connect the cartridge on the table withe 5cm of wire it buzzes, though I would exclude that the buzzing has anything to do with the turntable itself because the buzzing is happening away from the turntable if you get what I mean, also I have no space in the tonearm to run shielded wires.
What would you say?
Old 11th August 2019, 11:38 AM   #29
epicyclic is offline epicyclic  United Kingdom
Try this ... add another wire to the preamp ground post and connect it to the female RCAs ground/screen lugs at the turntable . At present the RCA screens may just be floating .
Old 11th August 2019, 11:40 AM   #30
I'll try this, thanks for the hint!
DIY Turtable Hum/Buzz issueHide this!Advertise here!
Hum and Buzz Issue fluid Solid State 2 15th May 2016 09:03 PM
Carver m200t capacitor/buzz issue finkbine Solid State 3 8th September 2013 03:39 AM
rega 3 slowing turtable speed solderon Analogue Source 5 22nd April 2012 07:56 PM
Melos triode and computer as source: BUZZ BUZZ BUZZ zigo3 Tubes / Valves 4 28th November 2007 02:11 AM
Asking for help with an old Beogram 1200 turtable andjur78 Analogue Source 0 27th September 2005 09:41 AM
Copyright ©1999-2019 diyAudio
