Modular phono preamp
Thread Tools
Old 9th October 2021, 11:43 PM   #11
Mark Tillotson is offline Mark Tillotson
I was tinkering with my distortion-measuring Python script and thought to do a THD test on my modular preamp via an inverse RIAA network through a 3rd-gen Scarlett Solo, getting a quite pleasing 0.00068% figure (including rumble filter, so 5 opamps in the signal path)
The software takes in a .wav file and iterates to a best-fit model sinusoid to match the data (in amplitude, frequency and phase), then subtracts it off to get the residual, and measures the correlation of the residual against harmonics of the model to get the red peaks and thus can measure THD and SNR separately.
I pre-processed with a 200Hz high-pass filter to knock off most of the mains hum components (wasn't measuring in a screened box, just on desktop) - otherwise this dominates the SNR (but doesn't affect the THD measurement).
[ The SNR ratio is fairly meaningless as I failed to record the actual level ]
I also measured the current consumption at 36mA per rail, which is as expected with 5 opamp stages per channel. Next step is boxing it up.
Old 10th October 2021, 07:45 AM   #12
DRONE7 is offline DRONE7  New Zealand
Did I miss that somewhere !!
Would be keen to try it...link ?
Old 10th October 2021, 10:09 AM   #13
Yup, here's the current version, Python 3
You need numpy/scipy/matplotlib/soundfile modules, and I forgot a few files, hopefully I've got all of them in the zip now.
  Reply to this post
Modular phono preampHide this!Advertise here!
Thread Tools
Acoustat Reference Modular Preamp reinhard Analog Line Level 4 7th August 2018 09:02 AM
Phono Preamp PCB wanted - Transcendental Sound Grounded Grid Phono Preamp nathanjh13 Analogue Source 0 14th June 2012 10:19 AM
Modular Balanced Preamp claas Analog Line Level 6 16th June 2011 02:39 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
