Opamp Phono Noise
Opamp Phono Noise
Old 3rd June 2019, 09:16 PM   #31
audiopro is offline audiopro  Canada
I'm not using any kind of measurement here as of yet. Strictly audible noise. My next step is to put them on the test rig, and measure noise and distortion. Then I'll find the best compromise IC for MM and for MC. It will probably be neither of these opamps.
I'm also using just what I have on hand, so as to not spend any money on this.
You are right. The TL071 does outperform the LT1028 on MM. I hadn't checked that initially.
Dan Santoni
www.dtsaudioelectronics.com
Old 3rd June 2019, 09:45 PM   #32
MarcelvdG is offline MarcelvdG  Netherlands
That will more or less boil down to choosing the op-amp with the lowest overall noise for a source impedance of about 1.2 kohm.
For a 500 mH moving-magnet cartridge and using RIAA- and A- weighting, the effective cartridge impedance is about 12 kohm.
The sensitivity of a moving-coil cartridge is typically about one tenth of the sensitivity of a moving-magnet cartridge.
When you noise-optimize for about a tenth of 12 kohm, noise current will affect the SNR with a moving-magnet cartridge about as much as the noise voltage will affect the SNR with moving coil.
Old 3rd June 2019, 10:00 PM   #33
tschrama is offline tschrama  Netherlands
op-37 or one of its modern equivalents then?
Servicing guitar and Bass amp, giving amp building workshops at my small atelier www.sgravenmade.com
Old 3rd June 2019, 10:02 PM   #34
dreamth is offline dreamth  Romania
Opamp Phono Noise
Opamp Phono NoiseHide this!Advertise here!
Replacing Dead Phono Opamp...What to Use?? EchoWars Analogue Source 38 10th October 2019 07:49 PM
May I have your ideas for this opamp>LCR>opamp>tube>output transformer phono stage Witti Analogue Source 17 31st May 2013 03:57 AM
Phono Stage OPAMP manolo2001 Analogue Source 2 11th October 2012 03:09 PM
Noise of discrete opamp robmil Solid State 11 14th September 2009 09:47 PM
New low noise opamp jackinnj Solid State 0 27th August 2002 06:51 PM
Copyright ©1999-2019 diyAudio
