Step Up Transformers inside the turntable?
Old 18th May 2019, 10:56 PM   #1
cyto is offline cyto  United States
cyto's Avatar
Default Step Up Transformers inside the turntable?
I have a SUT I built with Cinemag 1254s and I decided to place them inside my phono preamp to get rid of a set of interconnects and just because I want to.. It is a modified Hagerman Cornet 2 with an external PSU.
I got to thinking that if I put the step ups in the turntable (a highly modified Technics 1200, RCA jacks, external PSU, carbon fiber tonearm) then the very low MC output signal would be travelling a minimal distance. Regardless of where I put them I will install a bypass switch in case I put a MM cart.
I have never heard of someone putting the step ups in a turntable but I cannot think of a reason why I can't. I have training and used to be an electronics tech.
What do you guys think?
Old 18th May 2019, 11:07 PM   #2
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Well, turntables have a motor, and won't the motor have an electrical field around it which could be a source of hum for a SUT?
And, some turntables just don't have a place to put them.
jeff
Old 18th May 2019, 11:58 PM   #3
rayma is offline rayma  United States
Should work, especially if you use mu-metal to shield the SUT,
and keep it near the base of the tone arm.
Old 19th May 2019, 12:00 AM   #4
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Ortofon used to put the SUT in the headshell...
Old 19th May 2019, 12:02 AM   #5
vinylkid58's Avatar
Got a pic or a model number or something?
jeff
Old 19th May 2019, 02:30 AM   #6
cyto's Avatar
jeff
Good thought
Old 19th May 2019, 05:17 AM   #7
davidsrsb is offline davidsrsb  Malaysia
Typical LO MC impedance is close to most cable impedance, so long cables are do not cause any resonances. If you put the step up transformer in the turntable, all of the capacitance loading sensitivity reappears
Old 19th May 2019, 08:05 AM   #8
billshurv's Avatar
Ortofon SPU-T
Old 19th May 2019, 09:56 AM   #9
jcarr is offline jcarr  United States
David is correct. Any capacitance present between the SUT and phono stage will be multiplied by the square of the SUT's primary-secondary coil turn ratio. If the SUT gain is 20dB, any capacitance present between the SUT and phono stage will be multiplied by 100; a gain of 26dB will result in a capacitance multiplication factor of 400.
While there are benefits to placing a headamp so that it is closer to the MC cartridge and therefore farther from the phono stage, the reverse is true for SUTs.
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 19th May 2019, 11:55 AM   #10
cyto's Avatar
Thanks for the replies everyone, I will put them in the phono preamp.
Step Up Transformers inside the turntable?Hide this!Advertise here!
FS: Two Step Up Transformers cyto Swap Meet 1 30th April 2019 02:54 AM
MC Step-up transformers mantisory Analogue Source 62 1st March 2015 04:53 PM
Turntable too fast. Caps replaced. Next step? ZackR Analogue Source 1 21st July 2014 01:56 AM
bizarre bias, ST-70 experts step inside sphinx Tubes / Valves 5 20th December 2009 05:37 PM
Please rec. step-up transformers for ESL homemade Planars & Exotics 47 19th October 2005 08:25 PM
Copyright ©1999-2019 diyAudio
