Step Up Transformers inside the turntable?
Old 23rd May 2019, 04:43 AM   #21
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by billshurv View Post
...ones that are recommended to be loaded with that are generally under 10Ohms....
Name some, recommended load < 10 Ohms.
Old 23rd May 2019, 05:37 AM   #22
janho12345 is offline janho12345  Germany
You said that the cable length after the SUT will be short. And you ask why no one does it.
If you put the SUT at the beginning of a “length” of cable run, there is a significant high impedance signal running through (remember impedance is transformed in square) 1:10 -> 1:100.
If I’m not mistaken, we always try to make the output impedance of a low voltage signal as low as possible, especially if long cable runs are needed. Probably it has sth. to do with the Input impedance in order to not have a loss of signal. As well as the requirements to the cables themselves could be different.
Old 23rd May 2019, 09:01 AM   #23
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Miscombubulation. LOMC that are recommend to be loaded with 100Ohm generally have sub 10 ohm coils.
Old 26th May 2019, 12:02 PM   #24
cyto is offline cyto  United States
cyto's Avatar
Thanks for all the input. I put the step ups in the phono stage.
Step Up Transformers inside the turntable?Hide this!Advertise here!
FS: Two Step Up Transformers cyto Swap Meet 1 30th April 2019 02:54 AM
MC Step-up transformers mantisory Analogue Source 62 1st March 2015 04:53 PM
Turntable too fast. Caps replaced. Next step? ZackR Analogue Source 1 21st July 2014 01:56 AM
bizarre bias, ST-70 experts step inside sphinx Tubes / Valves 5 20th December 2009 05:37 PM
Please rec. step-up transformers for ESL homemade Planars & Exotics 47 19th October 2005 08:25 PM
Copyright ©1999-2019 diyAudio
